New Found Problem; Transfer Case Leak - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-27-2006, 02:20 PM
blownv6's Avatar
blownv6 blownv6 is offline
2003 Chevy TrailBlazer LT
Unhappy New Found Problem; Transfer Case Leak
It would figure after getting under my truck to look at the cat, I discover my Transfer case is LEAKING, I suspect the seal is bad. I sprayed it down, and cleaned it, and it continues to leak from the side seal and a pretty quick rate. This is just PEACHY, I love this truck, but it's getting to the point where I would consider getting rid of her now. I'd only settle for an SS TB AWD though
Since the above dream probably won't happen, DOES ANYONE HERE KNOW what GM Man Hour's the job out to be for a Transfer Case seal? I am pretty mechanically inclined, but do NOT want to tackle a xfer case.
D
Old 03-27-2006, 03:53 PM
Bulldog's Avatar
Bulldog Bulldog is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 2WD
Not sure of the man hours but I would have the dealer handle it so you have continued warranty coverage. If already out of warranty I would still stop by and let them give you a free quote, you never know they may cover the situation any way.
Bulldog
AKA "Terry"
Old 03-27-2006, 04:29 PM
speederscout1's Avatar
speederscout1 speederscout1 is offline
2004 Chevy TrailBlazer LT
Black w/Silverstone 2Tone 4.2L I6 2WD
When I went into the dealer about two weeks ago they also said my rear seal was seeping, they are going to fix it under my extended warranty, but I'll give you an update on the prices when I get it done. I too would settle for an AWD SS
Old 03-28-2006, 03:42 PM
blownv6's Avatar
There scary thing is, I am HIGHLY considering getting an SS now, only this time I wouldn't skimp out on the EXTENDED warranty. I got a 60k extended with this one, but obviously it wasn't enough.
a Brand new OEM transfercase is $1200, and probably about $300 to install. Do you guys think it would even be worth it to have a mechanic crack the case, and replace the seal on this? The amount of Labor involved might even out just replacing it!!?? A friend recommended a Jasper replacement, but I'm a sucker for OEM.
D
Old 03-28-2006, 09:33 PM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
If it's just an output shaft seal on the xfer case, that's no biggie. The seal can be removed after they drop the front drive shaft. Make sure the vent line for the transfer case isnt plugged. A plugged vent will cause internal pressure to build & cause seal seepage. Same goes for the front/rear diffs.
G/luck
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 03-28-2006, 11:47 PM
Spong's Avatar
Spong Spong is offline
TrailVoy Guru
2006 Chevy TrailBlazer LT
Zaino Shined Red Jewel 5.3L V8 4X4
This is why I bought a 6yr/100k bumper to bumper warranty with mine! I learned with my Jimmy that all kinds of stupid crap can go wrong that shouldn't
Old 03-31-2006, 09:37 PM
blownv6's Avatar
I am beside myself about the $$ I'll have to shell out.......Roughly $1650 total. It's the CASE seal that went bad......WHAT &%$!!! I almost cannot believe this. The vehicle is less then three years old......I am a Chevy diehard, but this is COMPLETE B$! Still love the truck, but am talking with 3 Dealers about an SS AWD BABY!
.................this close to having the same payment, and starting over for another 5.....WITH a 6/100k warranty.......
Having a 91 syclone, it almost seems fate......
D
Old 03-31-2006, 10:02 PM
Spong's Avatar
TrailVoy Guru
DO EET!!!!
Old 03-31-2006, 10:24 PM
MTPockets's Avatar
4.2L I6 4X4
Did they give you a breakdown on the cost? I'd try another dealer or two for a quote and would prolly try to find a reputable trans shop to do the repair. That's inexcusable for a 3yr old truck. If that price is consistant, a TB would be the LAST thing I'd buy again. I know s--t's expensive these days, but that is rediculous.
G/luck
Joel
Old 07-03-2007, 04:25 PM
bobomara bobomara is offline
Transfer case
Just left a private shop about the same thing (front seal on the transfer case). Looks like ~$450 parts & labor.
Similar Threads
Transfer Case Flush on a 04' trailblazerdude 4x4 Drivetrain 2 12-06-2007 07:26 PM
Shudder, Rocking Motion, Binding, Feels Like Vehicle is Stuck in 4WD mickdigler 02-09 Vortec 4.2L I-6 Engine and Drivetrain 9 10-02-2006 11:38 AM
Transfer Case Is Bad trailblazer02 4x4 Drivetrain 1 05-30-2006 11:36 PM
Transfer case shift control switch yup1957 4x4 Drivetrain 5 03-15-2006 03:02 PM
Transmission + Transfer Case Troubleshooting Black-Syth 4x4 Drivetrain 10 03-14-2006 02:03 PM
