12-15-2009, 02:40 AM
2006 Chevy TrailBlazer LS Cranberry Red Metallic 4.2L I6 2WD
Climate Control Light
I take my 06 TB to the dealer for a engine light error and they noticed one of the lights on the climate control (not digital) guage is out. How do i replace the bulb ?
Thanks !
12-15-2009, 11:28 AM
2006 Chevy TrailBlazer LS Summit White 4.2L I6 4X4
Hmmmm
Listening...I just ran in to the same problem. It's the left climate control knob; lights are totally out. I really don't feel like removing it for repair in the middle of winter...will probably do it next summer.
On a side note, I'm surprised that GM used a seperate bulb for each side/knob. Seems kinda "excessive" to me; they could've used just one and spread the light output to both sides.
12-15-2009, 12:08 PM
Yea i know what you mean ... how hard is the install ? is it a pita?
12-22-2009, 05:23 PM
2002 GMC Envoy SLE XL Magnetic Red Metallic 4.2L I6 4X4
same problem
my passenger side climate control light has also stopped working. How do I replace it?
12-22-2009, 06:12 PM
Senior Member
2002 Chevy TrailBlazer LS Forest Green Metallic 4.2L I6 4X4
The bulbs are not replaceable. They are soldered to the board. I broke my faceplate and the temp. control sliders trying to get the assembly apart. If it really bothers you that the light is out ebay has some used ones. I picked mine up for $40. New units go for around $180!!! Otherwise just deal with it. It's only a light for the hvac system anyway.
Lifted on 32's
01-30-2010, 10:17 PM
Senior Member
2006 Chevy TrailBlazer SS Silverstone Metallic 6.0L LS2 V8 2WD
Hmmm...my passenger side temp control (slider - non digital) light burned out, too.
I see a pattern here. And the light isn't serviceable?
Awesome.
Bruce
2006 TBSS LS 2WD Silverstone Metallic, VMT
01-30-2010, 10:20 PM
Senior Member
2004 Chevy TrailBlazer LS Dark Gray Metallic 4.2L I6 4X4
Mine burned out on my passenger side. Not worried about it, usually leave them pretty close to the same position anyway. If its the worse thing that happens, I can live with it
01-31-2010, 12:30 AM
Senior Member
2003 Chevy TrailBlazer LT Light Pewter Metallic 4.2L I6 4X4
LMAO my passenger side went out too. So I did some research on here and found that someone had mentioned hitting it, I flicked it a few time (right next to the slider) and its been on for like 6months or so now.
01-31-2010, 12:41 AM
2002 Chevy TrailBlazer LS Light Pewter Metallic 4.2L I6 4X4
Tapping it worked for mine. Eventually going to be doing the LED mod, but for now I just hit it from time to time and they come back on. Not sure if it is just a bad soldering job they did on them or what, but they go out randomly and tapping on the front with my knuckle gets them back on.
You may not post new threads
You may not post replies
