Temp. gauge for outside temperatures.... - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Interior
Interior Interior
Old 12-23-2009, 10:25 PM
NAH916 NAH916 is offline
2003 Chevy TrailBlazer LTZ
Summit White 4.2L I6 2WD
Over the last month, my digital temp gauge that tells the outside temperature has not been working right. It will either stay at 50 degrees, or magically start increasing or decreasing randomly. Is this something that can be fixed so my outside temp. gauge will work properly? Thanks in advance.
Old 12-23-2009, 10:29 PM
skoehlke skoehlke is offline
2002 Chevy TrailBlazer LT
Graphite Metallic 4.2L I6 2WD
Outside temp
This is an easy fix. You will need to go to an Auto parts store, online source or a dealer to get an AMBIENT AIR TEMPERATURE SENSOR.
This sensor is located behind your grille. You will have to remove the grill to access it, but that is also very easy.
There are several posts on this site that will provide you with the needed steps. I think it took me less than 30 minutes to remove and replace mine.
The sensor is not that much money.
Old 12-23-2009, 11:50 PM
Sounds really easy. Thanks for the help.
Old 12-24-2009, 12:46 AM
DJones DJones is offline
Senior Member
Summit White 4.2L I6 4X4
Thanks for asking the question. Now I know I am not the only one having this problem. In the past summer, I went a few days with the windows up (I like them down if I can) because it was 59 outside... Turns out it was actually 75.
Old 12-24-2009, 01:39 PM
the roadie's Avatar
http://forums.trailvoy.com/showthread.php?t=26347
