Battery age?, how to change - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-31-2006, 01:26 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
OK guys. Iwas thinking about it.
I think its time to change my battery before im stranded somewhere.
It has not given me any problems yet. Its the Original factory battery thats been in there since at least Aug of 2002. so that makes it about 44 months old..... so its about time for a change. (by the way whats the battery life rated at on these factory batts?).
Ok, so for you who have changed batteries- I think theres a bar that has to be removed so the battery comes out.. but what else? any tips or tricks?
any of you have trouble losing engine control settings? or is it as simple as take out and put in?
Ive heard stories on some of the trucks and passenger cars/
Old 03-31-2006, 01:39 PM
Envoy Fan's Avatar
Envoy Fan Envoy Fan is offline
TrailVoy Guru
2005 GMC Envoy Denali
Summit White 5.3L V8 4X4
If you got 44 mo that is real good life. Some start leaking way before that. Remove battery cables, battery cover and bar. There may be a hold down at bottom of battery. Loosten if it is present. Pull old battery out. Check for any leaking battery acid. If no leaks install new.
BILL
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
Go for it! ... Your factory battery is on borrowed time, they usually give up the ghost shortly after the 36 month warranty. Mine went south pretty much w/o warning at around 41 months.
Change out is pretty simple, you unbolt the support bar/strut and remove the battery cables. (Neg first to avoid accidents). Lift off the cover and loosen the hold-down bolt.....its not necessary to fully remove it, just lossen it and slide the battery forward and lift out.
Reverse the procedure for installing the new battery. - Takes about 15 minutes of time, if you have the wrenches handy.
If you just want a good battery, Wal-Mart's Everstart-Maxx series ($59) was CR best buy and fits under the cover. Also comes with 2 or 3 years of roadside assistance and free replacement.
Old 03-31-2006, 01:47 PM
MTPockets's Avatar
MTPockets MTPockets is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
I've had factory batteries last 5yrs+ without issue, but it's not worth pushing it. Just use caution if you are using an all metallic wrench on that positive battery terminal. If you hit the wrench on anything metal (ground it out) bad electrical things can happen! There was a recent post floating around in regards to this. Blown BCM was the result IIRC.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 03-31-2006, 02:03 PM
turbomike's Avatar
turbomike turbomike is offline
2005 Buick Rainier
Black 5.3L V8 2WD
If you haven't been removing and cleaning terminals once a year, you might have a problem removing the positive terminal from the battery.
Old 03-31-2006, 02:04 PM
rbarrios's Avatar
TrailVoy Guru
hopefully i have no trouble with that + terminal.
Old 03-31-2006, 02:33 PM
MTPockets's Avatar
4.2L I6 4X4
Hey good tip. The GM posts can be a farging nightmare! They will cross-thread nice & easy too. I wonder if never-seize or silicone grease would be good to put on the post threads?!?
Joel
Old 03-31-2006, 02:46 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Just use caution if you are using an all metallic wrench on that positive battery terminal. That's why you disconnect the negative side first. That way even if you do slip and touch sonmething metal while taking off the + side, it won't make a complete circuit and short out.
Old 03-31-2006, 03:03 PM
chunn7 chunn7 is offline
2007 Chevy TrailBlazer SS
Red Jewel Tintcoat 6.0L LS2 V8 2WD
I have an '02 also and we just changed the battery last week - it was completely dead. You're wise to do it before it's too late!
Old 03-31-2006, 03:17 PM
Trefilov22 Trefilov22 is offline
2004 Chevy TrailBlazer LT
Monterey Maroon Metallic 4.2L I6 4X4
Wow, thats a pretty low age for a battery, must be junky. My factory battery in my 1998 Mustang is actually still working.... 154k miles and 8 years later....
Trefilov22
Similar Threads
My battery deformed and releasing white vapor blackcool TrailBlazer / Envoy Chat 14 12-02-2007 04:44 PM
O2 sensor, age, price, and difficulty to change? rbarrios General 10 11-11-2006 06:55 AM
Has anyone had to change the battery in their TrailVoy? dtown 02-09 Vortec 4.2L I-6 Engine and Drivetrain 39 10-04-2006 12:44 PM
Battery cable replacement... APDMC6008 General 3 11-11-2005 11:04 PM
Battery cable breaking off wookiee2cu General 14 10-19-2005 08:16 PM
