07 Envoy A/C & Heater Recirculation Fan not functioning - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Interior
Interior Interior
Old 01-20-2010, 10:06 PM
CJEhlers CJEhlers is offline
2007 GMC Envoy SLT
Monterey Maroon Metallic 4.2L I6 2WD
My recirculation fan does not function at all. The A/C and heater both work with forced air, however I can't get the fan to come on. I have checked the fuses and connections under the dash/glove box area. Any ideas what part of the fan is causing the problem?
Old 01-21-2010, 02:50 AM
KNBlazer's Avatar
KNBlazer KNBlazer is offline
Senior Member
2004 Chevy TrailBlazer LS EXT
Steel Gray Metallic 4.2L I6 2WD
the recirculation fan will not come on unless your AC or Heater is already on... you will distinctly hear a change in air flow when you hit the recirculation button... if you hear nothing, then you might be in need of an actuator... however, I am not sure if there is one for the recirculation feature... I probably would put my money on there being a recirculation actuator, after all these have at least 6 actuators... what's one more... ... use the search feature above and search for recirculation ...
Old 01-21-2010, 03:05 AM
2007 GMC Envoy SLT
I should be more specific. The fan function on any level does not work. Any ideas?
Old 01-21-2010, 09:16 AM
the roadie's Avatar
Blower or the speed control module (assuming you have digital controls).
Have you checked the blower motor connector with a meter?
Old 02-17-2010, 07:36 PM
dkdk dkdk is offline
2005 Chevy TrailBlazer LT
Sandstone Metallic 4.2L I6 2WD
Ac delco p/n 15-72813
Hey ROADIE the HVAC GOD HaHa
My 2005 TB LT with digital dual controls is intermetently coming on / not working. I've read your post on the manual resitor pack etc. I went to the AC Delco site and came up with p/n 15-72813 for 05/06 trailblazers. GM parts number is 89018778 according to GMpartsdirect.com ($68.67). My question is this the rite AC Delco part? All these numbers confuse me
THANKS DKDK
Old 02-17-2010, 07:59 PM
the roadie's Avatar
Digital controls are discussed in this post:
http://forums.trailvoy.com/showpost....16&postcount=8
The AC Delco number 15-72813 you found is for the REAR blower speed control on EXT/XL models (long wheelbase). Not for you.
GM 89018778 is a good part number for the item you need. You can also take yours out and look at it for a label, since you might find the issue is overheated wiring connectors, not the module itself. Take a look before you buy anything. If wiggling the connector makes it work intermittently, you need to clean that up or also buy a connector pigtail.
What you really need from rockauto.com or Ebay or the aftermarket stores is ACDelco: 15-80567
Oh, BTW - I can't claim any sort of godhood - I'm merely the Oracle.
Old 03-06-2010, 12:59 PM
Voyeey_ Voyeey_ is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
Unhappy Recirculation doesn't occur.
Hay guys
Anyone can help addressing my problem posted here?
Please please tell me I don't have to lose an arm & leg at a service shop pleeeeeeeeeease
