How do I remove my valve cover? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-02-2006, 04:13 PM
Braves299's Avatar
Braves299 Braves299 is offline
Senior Member
2002 Chevy TrailBlazer LT
I'm trying to replace the valve cover gasket on my 4.2L I6. How do I remove that black thing on the right side of the engine? I'm guessing it's some kind of heat shield for the intake manifold? That big black thing. I don't see clips OR bolts, and I've been fooling with it for almost 2 hours now. PLEASE HELP!! I cannot remove the valve cover because ONE bolt is under that black cover (where the throttle body is).
Carl Lee Combs
July 8, 1944 - February 20, 2002
"Gone for now, never forgotten"
Old 04-02-2006, 04:16 PM
Braves299's Avatar
Senior Member
Here is a pic. It's that big black case that runs along the right side of the engine (where the throttle body is hooked into)
Carl Lee Combs
Old 04-02-2006, 07:18 PM
jay boy's Avatar
jay boy jay boy is offline
2007 Chevy TrailBlazer LS
Indigo Blue Metallic 4.2L I6 2WD
If I'm not mistaking the arrow the big black thing is the intake manifold. It would bolt to the side of the head and you would need a new gasket. Jay
Old 04-02-2006, 07:44 PM
MTPockets's Avatar
MTPockets MTPockets is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
Yep, the 'big black thing' is the plastic intake manifold. It looks like that has to come off. The coil overs and spark plugs will have to come out, plus any wiring or tubing that's in the way. Take some pics if you can!
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 04-03-2006, 01:51 PM
Braves299's Avatar
Senior Member
Yeah, it does have to come off. My problem was that I don't know HOW to take it off. I don't see how it is fastened at all... I gave up on it, and I'm back at school now. I won't be able to work on it again for another month.
Carl Lee Combs
Old 06-22-2009, 11:29 PM
toad43 toad43 is offline
2004 Chevy TrailBlazer LT
Manifold removal
So, did anyone figure out how to remove the intake manifold? I too am working at removing the valve cover. One post I read said that removing the throttle body would give enough clearance, but it's not looking that way.
Help!
Old 06-22-2009, 11:39 PM
PR PR is offline
2004 GMC Envoy SLT
Dirt colored. 4.2L I6 2WD
I haven't tried... or checked... yet I would think that you can pry-it-open in the middle?
You might not have wanted to break this part.
-- Robert1101
Old 06-22-2009, 11:42 PM
MajesticLT03's Avatar
MajesticLT03 MajesticLT03 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
A/C needs to be discharged and the A/C line running over the front of the valve cover needs to be removed
Old 06-23-2009, 12:14 AM
I'm not yet worried about the A/C lines running across the top front of the valve cover, it's the intake manifold I'm working on right now, since I can not access the valve cover bolts until it is moved.
I'm guessing the bolts are on the underneath side of the manifold and are very hard to get to. Just hoping someone has done this before and wishing there were step by step photo instructions.
Old 06-23-2009, 12:16 AM
Pry-ing it open just doesn't seem like a good idea since it doesn't open easily. I definitely tried that first, but it seemed more likely to break then to open.
Similar Threads
How to remove dash board (not just bezels) LeonPhelps Interior 26 08-29-2009 11:06 AM
Need Help. My Blinker got snapped.. John02Trailblaz General 9 07-13-2007 12:28 AM
Problems Trying to Remove the Driver Cover Air Bag System BUC NASTY 02-09 Vortec 4.2L I-6 Engine and Drivetrain 0 02-15-2007 12:45 PM
05 TB DOD status? muddy tires 02-09 Vortec 4.2L I-6 Engine and Drivetrain 19 07-28-2006 11:00 PM
Valve cover breather Laloosh OEM Issues 18 02-25-2006 07:44 PM
