Crank/Cam Sensor ... relearn? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-05-2010, 06:58 PM
Chir Chir is offline
2004 Chevy TrailBlazer LT
Tan 4.2L I6 4X4
Greetings:
I am about to replace the crank and cam sensors. I'm reading about a relearn process that needs to be done, but I may be confusing it with something else?
After replacing these two sensors, do I have to have this relearn process done?
I am replacing the sensors becuase of a rough idle and a code that was thrown. I don't recall the exact code, but it said that the cam and crank sensors were not alighned. I also have lost a bit of power and cruise control no longer works.
Thanks.
UPDATE:
These are the parts that I have --
Crankshaft Position Sensor
Camshaft Position Sensor
After a little more digging - I think I'm confusing the Crankshaft Position Sensor actuator (what I actually have) with the Crankshaft Position Sensor. I believe you only have to do the relearn if you replace the sensor, not the actuator -- correct?
Thanks again!
Old 02-06-2010, 02:30 AM
2003 GMC Envoy SLT
A Crankshaft Angle SEnsor (C.A.S.E.) relearn has to be done when the crank sensor is replaced.
Old 02-06-2010, 02:13 PM
Tan 4.2L I6 4X4
Is the Crank Sensor and the Crankshaft Position Sensor two different things or are they the same?
And the relearn isn't somethign I can do, correct? I need to take it to a dealer (or a mechanic with a special tool?) to do that?
Old 02-06-2010, 02:48 PM
christo829's Avatar
christo829 christo829 is offline
There's a way to run the relearn process without a TechII, but I'm having
trouble finding the one I saw for our vehicles. Here's one from the full
size chevy forums:
http://www.fullsizechevy.com/forums/...t-relearn.html
It's about a third of the way down the page.
Or just do a Google search for "CASE relearn without scan tool".
If I can find the other version I saw that was relevant to our models specifically,
I'll repost....unless someone else here finds it first.
Good Luck!
Old 02-06-2010, 06:13 PM
Tan 4.2L I6 4X4
Awsome! Thanks for the link.
I believe this is the procedure, so I'll post it here in case someone else is looking for it:
NOTE: If the Crankshaft Variation Relearn is not accessible through your scan tool (some truck applications 1998 & later), perform the relearn in the following manner:
1. Turn off all of the accessories. With the Air temperature sensor and Coolant temperature within 5 degrees (Centigrade) of each other, start the engine and let it idle in Park or Neutral for two minutes.
2. Accelerate the vehicle to 55 mph at part throttle. Cruise at 55 mph for 8- 10 minutes until the engine reaches operating temperature.
3. Cruise at 55 mph for another 5-6 minutes.
4. Decelerate to 45 mph without using the brakes, and maintain 45 mph for 1 minute.
5. Perform 4 deceleration cycles, without using the brakes, of 25 seconds each where no specific speed is necessary. Returning to 45 mph for 15 seconds in between deceleration cycles.
6. Accelerate to 55 mph and cruise for 2 minutes.
7. Stop the vehicle and idle for 2 minutes with the brake applied and the transmission in Drive (automatic trans.) or Neutral (manual trans.) with the clutch depressed. Refer to diagram A on page 8.
Old 02-09-2010, 02:08 AM
toad43 toad43 is offline
Relearn
After replacing my motor, it seems like a relearn is necessary. But all of the relearn procedures I see are with the motor running. Can it be necessary for the relearn to take place to even get the motor to start? Would there be a relearn problem if I am getting fuel and spark?
