Factory radio problems - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-14-2010, 03:22 PM
JoshH JoshH is offline
2006 Chevy TrailBlazer LS
Silver Mist Metallic 4.2L I6 2WD
Hi folks. I'm trying to find out some information for my sister and brother-in-law. They just got an 06 Trailblazer EXT on Friday, and the front tweeters in the door are the only speakers making any sound. Every blown speakers I've heard before usually make some sort of noise (however distorted it may be), but these aren't doing anything. I'm trying to determine if the problem is with the factory head unit or the speakers. Any help would be greatly appreciated. Thanks.
Old 02-14-2010, 03:39 PM
the roadie's Avatar
Somebody needs to pull a door panel and apply a meter to a speaker or two and see if they get a decently low resistance reading with the power off. But typically you need to use something extra to diagnose this sort of problem. Either a meter to see if the speaker's still a speaker, a 9V battery applied to the speaker terminals to see if the cone jumps and makes a noise, or a spare speaker wired to the dead one to see if the problem is the head unit or the speaker.
Like a dead home stereo system, without dragging over a spare speaker or amp or a meter, there's no way to diagnose something's dead.
One minor possibility if it's a new vehicle, and it has the RSA (rear seat audio) optional control unit for the rear passengers - if it's turned on, it automatically suppresses the rear speakers and activates some headphone jacks. Some folks have problems with their front speaker hardware, but a failure in the rear might be just this optional feature. Have them read the Owner's Manual, and if it's the typical used vehicle where the former owner's used their original manual for napkins and it's gone - just download a new one from a list under our "Resources" pull-down menu.
Old 02-14-2010, 03:40 PM
tjwelshv tjwelshv is offline
2006 Chevy TrailBlazer LT
Black 4.2L I6 4X4
well first what type of system do you have Bose or not Bose?
modders rule the world
Old 02-14-2010, 05:21 PM
brendanthemac's Avatar
brendanthemac brendanthemac is offline
2004 Chevy TrailBlazer LS
Imperial Blue Metallic 4.2L I6 2WD
I have a similar issue, but my rear speakers come on occasionally and the sound is fine (i.e. no blown speakers). I have a gut feeling that my stock 04 head unit is just fried internally. Happened after being in Mississippi for two or three summers, i really think the heat/humidity just jumbled or literally fried some stuff in there. For example, the rubber casing for my dc power adapter plug for my GPS literally melted one hot summer day. Let me know if i'm way off base here.
--Infidel--
OIF, OEF Vet
"Duty is the sublimest word in the english language." Robert E. Lee
Old 02-14-2010, 05:54 PM
We did pull the door panel today to take a look at the speaker. I was going to do some checking on things, but my brother in law didn't have a multimeter. I did try the 9 volt trick, and it did nothing. I didn't look, but I'm almost positive they don't have RSA. You are correct about the owners manual, and thank you for informing me about the available download. I think a big problem is the vehicle is a repo. There's no telling what the previous owners did.
It is not a Bose stereo.
Old 02-14-2010, 10:50 PM
chevtrlblzr's Avatar
chevtrlblzr chevtrlblzr is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
I heard of many speakers just quitting or cutting in and out on these trucks.
I don't remember ever hearing that the radio was doing that to the speakers. (I do have a bad memory though!)
My vote is the speakers are bad. As roadie said - try a known working speaker.
- Carlisle Truck Nationals
Aug 5 - Aug 7, 2011 - Was Awesome
Old 08-26-2010, 11:01 PM
02TBFan 02TBFan is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
I just got my 02 TB today and I have the same prob that the OP does. Absolutely no sound out of the door speakers. I do not have that that fancy bose system. It's a stock am/fm cd player model. The radio tunes in stations normally acts like it should. I'm going to rob one of the door speakers out of my 96 and see if its the problem. I have never heard of all 4 door speakers dying but anything is possible with these things..
2005 Trailblazer LT 4x4 Olympic White
Old 02-07-2011, 12:27 PM
bullardt bullardt is offline
Speakers not working
My 2005 trailblazer has had a problem with sound coming from the rear speakers and the driver side for some time. I read somewhere that it could be a ground problem or a serial data 2 problem. I have yet to hear or read if anyone has had the same problem and what they did to fix it.
Since the sound for the low fuel warning, the seat belt alarm, and the door ajar alarm come out of the driver side speaker, I don't have those either.
Any advice?
Tom
Old 04-19-2011, 08:41 PM
KCK831's Avatar
KCK831 KCK831 is offline
Summit White 4.2L I6 2WD
Did you ever figure out what your problem was on this issue? My radio will play stations fine but the cd's play for a bit and then start to skip then just quit and it says "check cd" and goes to whatever station I was tuned into before I played the cd.
Old 04-20-2011, 01:01 AM
concrete's Avatar
concrete concrete is offline
Black 4.2L I6 4X4
Stock speakers are trash! So many threads on this. Mine started with one not working and then went to 3 not to long after. Replaced the speakers and no issues since.
You wouldn't put brand new wipers on a busted a** windshield would you?
