ignition switch will not release key - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 02-16-2010, 10:06 PM
blazertech blazertech is offline
2003 Chevy TrailBlazer LT EXT
greetings, fellow Trailvoy members . any input would be appreciated. the ignition switch will not turn to the off position and release the key in our 2003 TB. it may be a problem with the shift lock solenoid. when the lever is in park and the engine is running, i can push the button and shift the lever without depressing the brake pedal. i can lock the lever by pushing it forward and maintaining pressure but still can't get the key out. anybody have any quik tips on how to free the key?
Old 02-16-2010, 11:41 PM
ibidu1 ibidu1 is offline
Envoy Trailblazer GMC Envoy SLT
Black 4.2L I6 2WD
These Trailvoys if the battery is dead the ignition will not release the key. Try putting jumper cables on the car or check battery connection.
Old 02-17-2010, 01:20 AM
Thank you for your suggestion, ibidu1. I double checked the battery voltage (it's good) and checked some fuses. No problems there. Then I went and checked some other posts. I was able to find the outline of the access hole for the column key release on the lower steering column cover. I used a dremel tool to drill and shape the hole. Then I partially pried apart the covers until I could see the brass-like plunger. A push with a pencil on the plunger while turning the key and out it came. Now to find out why the ignition is not switching to off. If and when I find the cause , I'll post it.
Old 02-17-2010, 01:36 AM
KNBlazer's Avatar
KNBlazer KNBlazer is offline
Senior Member
2004 Chevy TrailBlazer LS EXT
Steel Gray Metallic 4.2L I6 2WD
I was going to suggest the release method, which you already found...
btw, does your truck crank and fire up?
Old 08-09-2014, 11:34 AM
jamelfrazier jamelfrazier is offline
2006 GMC Envoy Denali XL
Black 6.0L LS2 V8 AWD
Igntion key would not release IGN A fuse blown
I had problem with a 06 Envoy Denali XL with 5.3 that the truck would not start, nor release the key from the ignition . I found ING A #34 40AMP fuse blown under the hood, in the fuse service panel .When I replaced the fuse it just blew again !I knew it was a shortage some where so short story is I did some troubleshooting .I found the metal shield plate on the starter rubbing against the hot + run battery cable wire that attach the starter! Check the shield plate you don't have to remove the start to complete this task!
