2004 Radio Wiring Diagram - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-20-2010, 06:42 PM
Ekim82 Ekim82 is offline
2004 Chevy TrailBlazer LS EXT
Gold 4.2L I6 4X4
Hey Everyone,
First post on here. I am trying to fix my stereo, my friend said he knew how to install my audio system and now my head unit wont turn off with the truck. I have to manually turn off the stereo. I need to get a hold of a wiring diagram of the radio and figure out what he messed up. Any Help is much appreciated. I have a 2004 TB.
Mike
Old 02-20-2010, 07:07 PM
the roadie's Avatar
Did your friend use an adapter for the install? Only way to get an aftermarket radio to turn off. Run a search or read the stickies, (I think there's one that discusses adapters.) They sell them even at Walmart, but you have to know what to ask for.
Old 02-20-2010, 11:06 PM
dolphins0905's Avatar
dolphins0905 dolphins0905 is offline
2002 Chevy TrailBlazer LS
Black 4.2L I6 4X4
there should be a orange wire for that to turn off and on ur radio with the car its a 12v accessory wire, blue is ur remote turn for you amp if u have one.
Old 02-20-2010, 11:46 PM
s3customs's Avatar
s3customs s3customs is offline
2002 Chevy TrailBlazer LT
There is no switched or acc wire behind the radio. if your talking about the orange acc wire at the ignition harness , yea you can go there for it but its not worth loosing factory functions that are ran threw the radio. get a gmos-01 and be done with it the correct way.
Old 02-21-2010, 07:50 AM
djarmy2004's Avatar
djarmy2004 djarmy2004 is offline
2005 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
If you have onstar and use it and like to hear chimes when you leave your lights on or when you dont wear a seatbelt use the gmos-1. that will keep all factory functions in your TB. If your not worried about that i would just tap into the ignition harness. That is how mine has been ran since day one without a problem.
Old 02-21-2010, 12:45 PM
awer25's Avatar
awer25 awer25 is offline
2005 Buick Rainier
Platinum Metallic 4.2L I6 2WD
Originally Posted by Ekim82 View Post
Hey Everyone,
Mike
Just to sum up the above posts, the obvious issue is that he connected both the switched and constant power wires from the radio to the vehicle's constant power - hence why it doesn't go off. You need to run a switched ("ACC") power wire to the radio's red power wire, while leaving the yellow constant 12V wire as is. You can do this by either using an adapter box (generally the GMOS-01, ~$75) or more cheaply and easily by tapping into the wiper fuse ($5).
PCM Tune|K&N CAI|Viper 5901|HID Lows & Fogs|Kenwood DNX9140 DVD/Nav|Alpine PDX-5 powering 2x Alpine SPR-17S & 12" Kicker CompVT
Old 02-24-2010, 03:58 AM
Gold 4.2L I6 4X4
Thanks for the help everyone. You have answered my question perfectly. I only have one more....does anyone have or know where I can find a list of the wires or a diagram of the wires and their corresponding colors?
Old 02-24-2010, 05:11 AM
Gold 4.2L I6 4X4
After some searching I have found my answer!!!! For anyone interested here is the wiring list for an 2004 TB
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Or the website I found it on......
http://www.modifiedlife.com/2004-che...iring-diagram/
Old 02-24-2010, 06:45 PM
xavieremu xavieremu is offline
2006 Chevy TrailBlazer LS
Dark Gray Metallic 4.2L I6 2WD
There are a few gm's newer than 2000 that have a switched power source behind the radio. Most are turned on by a data wire which is why you go to the ignition harness or by the gmos.
Old 02-24-2010, 08:39 PM
s3customs's Avatar
Originally Posted by ekim82 View Post
after some searching i have found my answer!!!! For anyone interested here is the wiring list for an 2004 tb
car radio constant 12v+ wire: Orange
car radio switched 12v+ wire: Yellow THIS WIRE IS NOT THERE IN AN 04 TB
car radio ground wire: Black
car radio illumination wire: Gray
car stereo dimmer wire: Brown
car stereo antenna trigger: Pink
car stereo amp trigger wire: N/a
car stereo amplifier location: N/a
front speakers size: N/a
front speakers location: N/a
left front speaker positive wire (+): Tan
left front speaker negative wire (-): Gray
right front speaker positive wire (+): Light green
right front speaker negative wire (-): Dark green
rear speakers size: N/a
rear speakers location: N/a
left rear speaker positive wire (+): Brown
left rear speaker negative wire (-): Yellow
right rear speaker positive wire (+): Dark blue
right rear speaker negative wire (-): Light blue
or the website i found it on......
^^^^ caps in your post^^^^
