What weight oil do you use? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 03-02-2010, 07:38 AM
JBMallory's Avatar
JBMallory JBMallory is offline
2005 Chevrolet TB EXT LT
Dirty White Boy 4.2L I6 2WD
I gave up on the 5w30 after my TB started with an annoying tick a few oil changes back. Now I used 10w40, south Florida where we have just come out of 40*F weather and next week will probably have 80*F weather. Half a quart of lucas every oil change as well.
How about you?
Old 03-02-2010, 08:17 AM
50655 50655 is offline
Senior Member
2003 Chevy TrailBlazer LS
Dark Spiral Gray Metallic 4.2L I6 2WD
Im due for an OC now, I am currently using Castrol Syntec Blend 5w30 but going to be making the switch to full synthetic. Just under 80k and no problems.
Old 03-02-2010, 08:43 AM
fire06 fire06 is offline
2006 Chevy TrailBlazer LT EXT
Silver Mist Metallic 4.2L I6 4X4
I use Amsoil Signature series 0W30 and it has been great. The extend oil changes are only a bonus. Good luck in your oil choice. I have used in my car with no issues and it has over 200k miles on it.
Old 03-02-2010, 08:57 AM
JBMallory's Avatar
I like my oil to come out of the ground lol. I used royal purple (at $8.00 a quart) in a Jeep WJ I owned and only got 72k out of a 4.0 liter when I had at least 3 XJs with 4.0's go 150k before I sold them and one go 220k before I sold it, using dino oil
Old 03-02-2010, 12:13 PM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
I have only used 5W-30. I've never seen a reason to use anything else. It protects well even in the 115 degree heat of Southern Ca. and Arizona deserts.
Old 05-14-2010, 03:47 PM
TonyTrailblazer TonyTrailblazer is offline
2007 Chevy TrailBlazer LS
5W-30 or 10W-30
Typically 5W-30 will give a good balance of engine protection and fuel economy. But, if you live in a hotter climate and/or plan to put the engine under more stressful driving condition, you might want to consider 10W-30.
Other than these two grades, I don't know what is acceptable for the 4.2 I6 engine. And ALWAYS use an oil that carries the GM spec GM6094M. I stick with Mobil-1 or Castrol Semi-Synthetic.
Good Luck.
Tony...
Old 12-24-2013, 11:50 PM
Beakersloco Beakersloco is offline
2003 Chevy TrailBlazer LS EXT
Summit White 4.2L I6 4X4
New owner here and mine has 150k on it and im thinking of putting 10w-30 in it since it has over 100k miles in it and Im here in the carolina where it gets hot during the summer months and in the 30-40s on average in the winter months.
Anyone think I should still use 5w-30 ?
Old 12-25-2013, 02:10 AM
Senior Member
I think the 5w30 would be best. It gives good protection in the warmer months and has a thinner viscosity to facilitate cold weather starts etc.
Old 01-13-2014, 03:42 PM
Tri Tri is offline
Lurking Newbie
I'm in need of my first oil change I'm mostly in cold weather which would be best from my truck 5w30 or the 10w30
Old 01-18-2014, 06:38 PM
mpd13078 mpd13078 is offline
2002 Chevy TrailBlazer LT
I've always used 5w-30, but now high mileage type since 75K miles...I'm at 120K miles now. OEM oil filter, too. Still running strong & reliable for me.
Mike
