RPM's jumping - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 03-05-2010, 12:20 AM
502TB 502TB is offline
2002 Chevy TrailBlazer LS
Black 4.2L I6 2WD
Question RPM's jumping
When ever I'm driving at a steady pace i can feel the truck jump and when I take a look at the rpm's i can see the hand bounce up a notch or two. I was told it could be the torque converter, but i was also told it could be a clogged cat. converter. One thing I'm unsure of if it's having an issue going into overdrive or if the issue is occuring while in overdrive. I can feel the truck shift into each gear but not sure about OD. Any ideas by chance what may be causing this?????
Old 03-06-2010, 08:40 AM
Black 4.2L I6 2WD
any possible ideas guys???
Old 03-06-2010, 09:52 AM
JerryIrons JerryIrons is offline
2006 Chevy TrailBlazer LS EXT
How many miles do you have? Any engine codes? Have you dropped the tranny pan and changed/examined the fluid? Does it still happen if you stay in 3rd? I think a clogged cat converter would cause more trouble than this but I'm guessing on that one.
Might help:
http://forums.trailvoy.com/showthrea...pm+jump+steady
Old 03-06-2010, 10:00 AM
Black 4.2L I6 2WD
109,000 is the mileage... I just went and got the trans fluid and rear diff. changed out... didnt feel any jumping but i havnt been up to speed to notice the problem yet. I havnt thought about driving in 3rd to see if the problem persists, will do!!!
Old 01-26-2014, 08:41 PM
DayDaysmom DayDaysmom is offline
Lurking Newbie
Any conclusion on this?? I'm having the same problem.
