Changing rear lift gate struts - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-08-2010, 11:54 AM
papos2002 papos2002 is offline
2002 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
Ok I have searched and didnt really find it. Does anybody have a write up on how to do this.
Thanks Guys!
Old 03-08-2010, 12:15 PM
the roadie's Avatar
They're usually very self-evident. What specifically are you concerned about?
Old 03-08-2010, 04:56 PM
Black 4.2L I6 4X4
I cant figure on how to take them off, not sure if I should just pull them off.
Old 03-08-2010, 05:10 PM
rsnow46's Avatar
rsnow46 rsnow46 is offline
2006 Chevy TrailBlazer LT EXT
They ususally last a long time. If you want to change make sure you put a 2x4 and snug it tight against the top so the tailgate won't fall on your head. Take needle nose pliers and pull the retaining ring around the top ball while you jiggle the liftgate, the strut should slide off.
Let the door rest on the 2x4. Do the same on the bottom ball and remove strut. Before you install new one put a little dap of grease on ball (sometimes the new strut comes already greased).
On the new strut all you have to do is push until it snaps on. Do the same on the bottom. Then do everything the same on the other side. Just make sure the board is secured - the liftgate is heavy.
Old 03-08-2010, 05:34 PM
Black 4.2L I6 4X4
Thanks!!
