no speedometer, ABS light and Parking Brake light are on - after replacing mount - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-11-2010, 05:04 PM
dozz dozz is offline
2003 Chevy TrailBlazer LT
Pewter Metallic 4.2L I6 4X4
i just replace the transmission mount on my 03 Trailblazer. now the speedometer doesnt work and both the ABS and Parking Brake lights are on. is there a wiring connection around the transmission that would affect all of these that I may have damaged? if not, any other thoughts?
Old 03-12-2010, 03:17 AM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
You may have fiddled around with the speed sensors on the tranny itself. IIRC there are two that correlate with each other. I'll try to find a diagram pointing out where they are, but in the meantime look for any loose wires or connectors.
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 03-12-2010, 09:49 AM
I have disconnected and reconnected all wires I find going to the transmission. My understanding is that the speed sensor that feeds the speedometer is on the back of the transmission (near the transmission mount). unfortunately, i didnt see the wire as we lifted the transmission to replace the mount and may have stretched it hard enough to create a short. Is there a way to test and replace, if needed, the connector that plugs into the speed sensor?
Old 03-12-2010, 09:08 PM
i found a wire that runs along the passenger side of the transmission (has green and purple wires) that i accidentally pinched between the transmission and the transmission mount. i cut out the broken area and soldered back together. it appeared to fix the problem for a couple miles but then the ABS and brake system lights came back on (my speedometer is working now though) and a few miles later all of a sudden the radio went off, all the dash warning lights came on, the gauges went dead but the engine kept running - then a quarter mile or so later the radio came back on, the gauges started working again and only the security and ABS lights stayed on. by the time i got home the brake system light also came back on.
what have i done?!
Old 03-12-2010, 09:21 PM
waggiecam waggiecam is offline
2004 Chevy TrailBlazer LS EXT
Black 4.2L I6 4X4
From what I have read on trailvoy in the past it sounds like it could be your ignition switch going bad.
Old 03-12-2010, 10:44 PM
mdeaton mdeaton is offline
2002 Chevy TrailBlazer LT
I had the abs light brake light and speedometer problem a couple weeks ago and it turned out to be a busted o-ring on one of the speed sensors
Old 05-21-2015, 03:46 PM
Xtreme_lyb Xtreme_lyb is offline
2002 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
I know this is old, but I have the same problem. After 3 weeks of not moving and starting my 02 trailblazer, I turned on my blazer and encounter this same problem. Any more info on this matter?? Thanks I'll appreciate it
