A/C High Side Service Port - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-08-2010, 03:24 PM
dcw dcw is offline
2004 Chevy TrailBlazer LS
Liquid Silver Metallic 4.2L I6 4X4
The high side service port is on the passenger side of the engine compartment on the line exiting the condenser, correct?
Usually the high side port is between the compressor and condenser, but this is the only high side port I can find.
Old 04-08-2010, 10:30 PM
c good c good is offline
Senior Member
2002 GMC Envoy SLT
Correct. On the passenger side. High side service port is under the cover that goes over the top of the radiatior and condenser. I drilled and dremeled out a hole on this cover to let me hook up guages to it without pulling it off each time I service it. It is just by the clip that holds the hood prop rod down. That's the only high side port that I'm aware of. The low side is on the accumulator/dryer. HTH c good
You may not post new threads
You may not post replies
