Front brake rotor minimum thickness - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Brakes
Brakes Performance Brake Upgrades
Old 04-12-2010, 11:30 AM
JM-TrailBlazer JM-TrailBlazer is offline
2006 Chevy TrailBlazer LS
Sandstone Metallic 4.2L I6 4X4
Hi all. Does anyone know the minimum thickness for front brake rotors on a 2006 TrailBlazer LS 4WD?
Old 04-12-2010, 11:38 AM
jimmyjam's Avatar
jimmyjam jimmyjam is offline
TrailVoy Guru
2006 Chevy TrailBlazer SS (LT)
White 402ci Other AWD
27.5 mm, 1.08 in
Old 04-12-2010, 11:49 AM
thanks jimmyjam
1.14" thick puts my rotors in spec. Thanks jimmyjam!
Old 04-12-2010, 12:21 PM
bullethole's Avatar
bullethole bullethole is offline
Senior Member
2002 Chevy TrailBlazer LT
It's stamped on the rotor also.
Troubleshooting rule #1 : Check the simplest and least expensive things FIRST!
Old 04-12-2010, 06:20 PM
thanks bullethole
I just popped the wheel off to measure the rotor thickness, but didn't see the stamp. Maybe it has to be taken off to see it? Thanks again.
Old 04-13-2010, 10:58 PM
bullethole's Avatar
Senior Member
Yes . It will be on the back. You will need to take it off.
