[SOLVED] Bought new Sway Bar Bushings! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 04-23-2010, 10:09 AM
Trailblaze_2002's Avatar
Trailblaze_2002 Trailblaze_2002 is offline
Senior Member
2002 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
Ok so i just bought some new Sway Bar Bushings and payed a pretty penny for them but they are Polyurethane all around for the rear and front sway bars. The price of the items wasn't to bad but the price for the Shipping was awful! 18.00 dollars fore shipping and i will be giving feedback on the products and the costumer service. Here's the site link http://www.suspensionconnection.com/...lift_kits.html Hopefully this site helps you all out with all your suspension purchases. Like i said shipping is steep but the products look to be good quality will find out in a few days for sure though. I'll keep you updated. Wish me luck!
They have a Air ride air bag kit that has a lifetime warranty for like 80.00 dollars so they are pretty reasonable except on the shipping.
P.S. I even ordered some Underbody Coating and i will be sanding it all down under there while i'm at the Bushings and spraying on the underbody coating.
"Before you embark on a journey of revenge, dig two graves."
Old 04-23-2010, 10:28 AM
DJones DJones is offline
Senior Member
2003 Chevy TrailBlazer LTZ
Summit White 4.2L I6 4X4
Good luck!
Old 04-27-2010, 05:12 PM
gmdude2004's Avatar
gmdude2004 gmdude2004 is offline
Senior Member
2009 SAAB 9-7x
Onyx Black 5.3L V8 AWD
Nice I like your thinking!
Old 05-07-2010, 03:22 PM
Senior Member
Well got the bushings 2 days ago and put em on wallow go gonna go for a test drive after i change the oil. I'll let ya know what happens but i think i may still have the noise cause i rocked it from side to side and it's still there but faint. We'll see hope it's fixed after a bit of driving. Wish me luck!
Old 05-07-2010, 03:30 PM
coolcloo1019's Avatar
coolcloo1019 coolcloo1019 is offline
Senior Member
2002 Chevy TrailBlazer LTZ
Indigo Blue Metallic 4.2L I6 2WD
Did you change the swaybar end-links? That's usually what causes any front end noise.
Old 05-07-2010, 03:35 PM
Senior Member
actually did that just before the bushings. Did them all around bushings and links also upper ball joints. Letting the oil drain now, then gonna finish up and take it for a test run.
Old 05-07-2010, 05:21 PM
Senior Member
Yea the damn noise is still there I will be doing an extensive search for this noise its !?! It does ride smoother now though and take the curves good.
Old 05-07-2010, 05:32 PM
izzyduzit izzyduzit is offline
x x x
x Other AWD
Mine makes noise when you rock it side to side too. Turns out it's the bug deflector on the front. Can you have somebody rock it back and forth while you try and locate the noise? Try spraying WD-40 on one part at a time and see if it quiets down any. Good luck finding it.
Old 05-07-2010, 07:27 PM
Senior Member
Update the noise is in fact the Sway Bar End Links because they have loosened up from not being properly torqued by my dumbass! I guess that shows that you need to use thread locker and tighten properly the first part i did(thread locker) just didn't tighten properly. Aw well everyone is entitled to a few mess ups right?
Old 05-07-2010, 09:59 PM
Senior Member
So i tightened the Links up to the proper 74 ft lbs and no more clink clink! Yay lol it rides like an old beat up caddy now but hey at least it rides like a caddy!
