where is the location of the oil pressure sending unit on a 2004 6 cyl - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 04-27-2010, 06:03 PM
blue52 blue52 is offline
2004 Chevy TrailBlazer LT
My oil psi gauge drops to zero at idle. message came on to shut engine off. There is No engine rattle and the engine runs fine. ? oil sending unit?
Old 04-27-2010, 06:07 PM
bartonmd's Avatar
bartonmd bartonmd is offline
Basic Vendor- Skid Plates
2007 Chevy TrailBlazer LS
Could be, but this engine is DOHC, so you won't get lifter knock when the oil pressure is low... You should get rod knock when there is NO oil pressure, though...
I'd personally put a physical gauge on it to make sure exactly what it's running (like a test gauge)...
Mike
The GB ended, but PM me if you want one!
GB also ended, but PM me if you want these!
Old 04-27-2010, 07:52 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
The oil sending unit (gm calls it the oil pressure sensor) has a high failure rate.
I've had to change mine, and a number of others have reported failure as well.
It's mounted just above the oil filter
Pull the filter and it's right there.
Ray
