P1481 Code on 2003 Envoy - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Air Induction
Air Induction Performance Air Intake/Air Induction Modifications
Old 05-08-2010, 09:01 PM
JJfisher JJfisher is offline
2003 GMC Envoy SLT XL
Exclamation P1481 Code on 2003 Envoy
I just pulled a code P1481 and my cooling fan sounds like a jet engine. The code said something about fan speed. It sounds like it is stuck on high. I was wondering if anyone has had this problem. Not sure if it could be a relay or if it is something else. Perhaps the fan clutch that i have heard so much about. My temp gauge has been normal, truck not overheating at all. Please help
Old 05-08-2010, 09:19 PM
the roadie's Avatar
Most certainly the fan clutch, but just unplug the harness going to it to confirm it's not the relay. If it stays on high speed, it's bad. Pre-2005 were the ones prone to early failure.
Lots of threads about changing them.
Old 05-08-2010, 09:24 PM
Thanks for the help. Know were i can get a good deal on one. I priced one at O'rielys auto for 170.00 ish
Old 05-08-2010, 11:18 PM
the roadie's Avatar
Dorman (a good aftermarket supplier) makes them and they've been seen for $110-120 on Amazon and Ebay. Rockauto has them for $132.
Old 06-21-2010, 12:49 PM
hullman8 hullman8 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
Is the relay bad or the fan clutch? I just replaced my fan clutch and it still sounds like a jet engine. How would I test the relay?
Mike
Old 06-21-2010, 03:06 PM
the roadie's Avatar
Relays hardly ever fail, but you have a point. Swap 45 and 46 - they're the only two identical ones in the front fuse block. The other one is for low beam headlights and the DRL function.
Old 07-01-2010, 02:03 PM
atblack21 atblack21 is offline
2003 GMC Envoy SLT
I am in the same boat. I just tried that and the relay is still good. I did replace my fan clutch. Twice. When I switch the relays, the AC is still screwed and the low beams work.
Tags
cooling fan, cooling system, fan clutch, fan relay, p1481
