Replacing the shift cable on 02 TB - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 05-15-2010, 08:36 AM
Bruces 57 Bruces 57 is offline
2002 Chevy TrailBlazer LS
Sand Beige Metallic 4.2L I6 2WD
Hello;
I am a new guy here but not new to forums and a wealth of info that members may have.
My problem is I am not too framiliar with newer cars (thats why I drive a 57 Chevy) but my wife likes our 02 TB just fine.
The other day, My wife calls me and can't get the TB shifter to move! I call a mobile mechanic that works on our vehicles at work to meet me and give it a look. He gets under the car and discovers that a nylon (looks like a bushing) clip is broken and the shift cable is off the transmission. He states, showing me the part, "I'm Going to fix this so you can use the car, but you need to replace the cable".
Now, my question, Has any of you done this replacement?? do you have any photos to share or a link to a page in a manual?
I don't think (other than special tools) this would be too hard to do as I have done just about everything to my 57 you can imagine as well as some you can't imagine.
Bruces 57
Old 05-15-2010, 11:00 AM
the roadie's Avatar
Welcome. We use www.compnine.com to get exploded drawings like this.
Old 05-15-2010, 04:38 PM
Hello;
Thank you for steering me in a direction to find some help. The job doesn't look too hard the only thing I am concearned about is taking the console apart to get to the cable end on the shifter.
I will try the link to see if the console has an exploded view.
Bruces 57
Old 05-22-2010, 12:04 PM
Hello, Me again:
Did the cable this morning. As I can't work on vehicles at my house (HOA) I drove the TB to my work and did it there! Elapsed time with cleaning everything before re assembly is an hour and a half! Hardest was the console removal (I knew that) and geting the cable out and in under the carpet.
Discovered that there must be a leak somewhere as the carpet wasn't wet but the padding was soaked! (next to fix that problem)
The Chilton manual I got gave me a lot of good info and some pretty clear photos altghough little things arn't clearly explained sometimes.
Anyone doing this job, if you have any experience at all will find it pretty darn easy. One of the hardest things was to disconnect the power plug inside the console in order to completely remove it.
Bruce
Old 08-22-2010, 10:49 PM
autonovice autonovice is offline
2002 GMC Envoy SLT
Red face Thanks so much- very helpful, but...
have you any idea if this replacement pin (see link below) would really work for GMC Envoy and how do I remove the nut and replace it holding the lever/arm in place without overtightening it and damaging the transmission, or is this not a concern? Check it out. Thanks.
http://www.atfbilletparts.com/shifte...pair-pin-p-560
Old 08-27-2010, 11:41 AM
2002 GMC Envoy SLT
Fixed GMC gear shift cable disconnect problem for $30
Highly rec this site for fixing the connection of gear shift cable to the lever.
http://www.atfbilletparts.com/shifte...pair-kits-c-21
Old 01-20-2014, 12:36 PM
khuckel78 khuckel78 is offline
Lurking Newbie
is there a way to buy just the part numbered 9?
