Oil Change interval? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-17-2010, 12:16 PM
Houbie's Avatar
Houbie Houbie is offline
2002 Chevy TrailBlazer LS
Onyx Black 4.2L I6 2WD
Question Oil Change interval?
I changed oil in my '02 Trail Blazer and changed to Mobil 1. The lube shop in Murrieta CA put a 7,500 mile sticker in the window. Is Mobil 1 good for that many miles? I put Penzoil synthetic in the wife's LaCross this past weekend and the lube guy says 5,000 miles on the Penzoil. I have a little over 5,000 miles on the Mobil 1 and the 4.2 hasn't used a drop.
Thanks,
Houbie
Golf is not a matter of life and death, it's far more important than that!!
Old 05-17-2010, 12:30 PM
mubai's Avatar
mubai mubai is offline
2002 GMC Envoy SLT
Go by the DIC. It will tell you how much life you have left. 7500 seems like a good number. Some don't change until 10,000.
208,000 miles...
Old 05-17-2010, 01:25 PM
Atlwrk's Avatar
Atlwrk Atlwrk is offline
2006 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
Changed mine this weekend at 12,000+ miles after finally getting the change oil light. Had Mobil 1 synthetic extended life (15,000miles). Replaced it regular Mobil 1 synthetic and will stick to the oil life monitor.
Haven't heard of any engine issues or bad oil analysis from someone following the OLM.
A little bit of knowledge is a very dangerous thing.
Old 05-17-2010, 02:46 PM
Houbie's Avatar
Talking Gulf Oil reclimation?
I'll go the 7,500 and see how it goes. Maybe BP can reclaim enough oil out of the Gulf to give us a few free oil changes.
Thanks for the info,
Houbie
Old 05-17-2010, 02:50 PM
Doc Brown Doc Brown is offline
Senior Member
2003 Chevy TrailBlazer LT EXT
7500 on synthetic? I get that out of dino oil. I'm thinking you aren't going to get the full life and benefits of synthetic by changing it that soon.
Old 05-17-2010, 06:42 PM
jacob789456's Avatar
jacob789456 jacob789456 is offline
Senior Member
2002 Chevy TrailBlazer LTZ
Red Jewell/Pewter 2-tone 4.2L I6 4X4
We go about 7500 on Mobil-1 and will go longer as I continue to use synthetic oils. I just switched from Dino 5K miles ago. TB has 135K on it.
02' Trailblazer LTZ 4x4 with 3.73's & G80
Old 05-17-2010, 07:03 PM
DJones DJones is offline
Senior Member
2003 Chevy TrailBlazer LTZ
I say go until the "Change Eng Oil" light turns on. And for the record, I have the DIC and it says I have 85% left and I've gone over 2,000 miles (I do plenty of highway). I use Mobil-1.
Old 05-17-2010, 07:08 PM
OldSVTGuy OldSVTGuy is offline
2004 Chevy TrailBlazer LT
I wouldn't trust that "change oil light" for anything. First time it came on was 11,000, then 23,000 then something like 40,000 then 70,000, then 100,000. No way oil change intervals should be this long under any circumstances. I've changed it every 3,000 miles religiously and it starts looking fairly dark by then. Cheap insurance, very cheap insurance.
Anyway, that's my .02.
Old 05-17-2010, 08:23 PM
lbls1 lbls1 is offline
2008 Chevy TrailBlazer SS
Black Granite Metallic 6.0L LS2 V8 AWD
Hate to be a dissenter, but driving the car past the service interval until the "change oil light" appears should never happen. The longest interval you should leave oil in the crankcase should be the recommended service mileage in the owner's manual. If you guys and ladies are adding oil between extended change intervals or are waiting for a "change oil light" then you could be doing more damage to the engine than necessary.
I've changed oil at 3,000 miles on the mark (as a preference), and I have avoided engine breakdown, excessive engine wear and oil usage issues on my past cars. I have also seen cases where premature engine wear and breakdown have occurred from infrequent oil maintenance. I've changed oil at 1100 miles on some cars (stored) so as to help keep engine wear down by maintaining clean oil in the crankcase. A lot of people go farther than 3,000 miles, so I would say that one should keep an eye on the cleanliness of the oil and change it at the recommended service interval.
'02 CAMARO SS SOM
'08 TBSS AWD Black Granite Metallic
Old 05-18-2010, 01:10 AM
2003 GMC Envoy SLT
This is what the Owners manual recomends: Change engine oil and filter as indicated by the GM Oil Life System or every 12 months, whichever
occurs first
