Changing Rear Shocks - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 06-01-2010, 05:21 PM
kodeblue71 kodeblue71 is offline
2004 Chevy TrailBlazer LT EXT
Pewter Metallic 5.3L V8 4X4
I searched and came up empty on replacing rear shocks. Is there a how to on here or am I missing something? I would like to tackle this myself.
Old 06-02-2010, 01:31 AM
the roadie's Avatar
No need for a how-to. Four bolts. Take off the tires to save a couple of minutes. Most folks with tools can change them in under a half-hour for the pair. Without tools, as long as it takes you to drive to a buddy's house who has tools.
The fronts are tough.
Old 06-02-2010, 10:34 AM
CHINGON81's Avatar
CHINGON81 CHINGON81 is offline
2003 GMC Envoy SLE XL
Silver Green Metallic 4.2L I6 2WD
Link to "how-to" 4 rear shocks
http://www.trucktestdigest.com/TTDfe...ockInstall.htm
Follow the link above, it tells you the tools you need and the procedure. and if you still need help just ask. Thats what were here for, to help each other out.
2003GMCEnvoyXL 2005PontiacG6
Old 06-02-2010, 11:30 AM
Thanks for the info guys and the link. I did not know it was that easy to do the rears. I only asked because I have never messed with shocks before and did not know if there was a load or not like the front.
Old 11-09-2010, 11:14 AM
monimatu monimatu is offline
2005 GMC Envoy Denali
Black 4.2L I6 4X4
thx
just replaced the rear airbags on my gal's envoy.
the right rear shock is shot due to the air bag being deflated, i'm assuming.
anyway, great post as i was searching whether or not i'd b able ot do this replacement myself.
thx for the thread + link.
Old 11-09-2010, 04:51 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
the rears are easy.
I changed mine by laying on my back and undoing the nuts.
Did NOT remove tire.
Did NOT lift the vehicle.
About 30 min time.
Old 11-09-2010, 07:51 PM
Black 4.2L I6 4X4
Originally Posted by rbarrios View Post
the rears are easy.
About 30 min time.
thanks for the info. i'm glad to see it's fairly easy
Old 11-22-2010, 03:30 PM
droptine1968 droptine1968 is offline
2006 Chevy TrailBlazer LT
maroon 4.2L I6 4X4
the rears are easy.
About 30 min time.
Did you use a floor jack to take any pressure off the shock?
Old 11-22-2010, 05:17 PM
the roadie's Avatar
Except for gas pressurized shocks, there is NO pressure on the shock, and even a GP shock can be pushed into place by hand. It's not like they're a spring.
Old 11-22-2010, 07:56 PM
Chickenhawk's Avatar
Chickenhawk Chickenhawk is offline
Senior Member
What Roadie said.
Less than 10 minutes a side if you have a handy little portable torque driver like I do. No jacking; no removing wheels.
The top bolts don't even need a wrench on the other side because GM uses a blind nut.
Tags
change rear, shocks
You may not post new threads
You may not post replies
