Windshield Washer Reservior - Replacement - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 06-23-2010, 02:30 PM
Bill M Bill M is offline
2005 Chevy TrailBlazer LS
Steel Gray Metallic 4.2L I6 2WD
Hi everyone...New to this board.....So please forgive if I do something wrong.
I was just informed by a dealership that my windshield washer reservior is cracked and I think that they are right, because it will not hold water and leaks every where....
How difficult is this job to accomplish? The dealership told me $285 dollars...and I think that I can do it for a whole lot less...just do not know where to start.
If I am not mistaken, 2005 TB - Reservior is on the passenger side under engine compartment....Doesn;t look that difficult....but you never know...
Thanks in advance for the help.
Old 06-23-2010, 03:20 PM
drolds72 drolds72 is offline
2002 Chevy TrailBlazer LT
its underneath your air cleaner assembly. Remove that, and the resivoir should be held down with a few bolts. Very straightfoward R&R.
Old 06-23-2010, 03:26 PM
RDFABSREP's Avatar
RDFABSREP RDFABSREP is offline
2006 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
It may be located below the airbox, but you might only be able to physically remove it through the wheel well. Extremely easy job, and you'd probably be able to patch it with epoxy and call it a day.
Old 06-23-2010, 04:51 PM
Thanks for the help
Guys,
thanks for the help.....Doesn't seem that difficult.....I will attemp this weekend...and I will let everyone know how it turns out...
Thanks Again...Nice Website & forum
Old 02-17-2011, 09:41 PM
GfabSabfd's Avatar
GfabSabfd GfabSabfd is offline
Leaky windshield wiper reservoir
Windshield fluid slowly drips out of the pump for the rear windshield fluid. Does anyone have a fix for this I had the same problem two years ago. I took it all apart and reseated the two little pumps. It worked until now, any other fixes or ideas would b appreciated thanks.
Old 02-14-2014, 09:14 PM
myvoy05 myvoy05 is offline
2005 GMC Envoy SLT
just bought an 05 envoy. put in a gallon of windshield fluid and now its gone. LOL so is it really difficult to replace reservoir?? If not I'm seeing online a reservoir for like 40 bucks but it says for models without rear wiper??
Old 02-14-2014, 10:25 PM
Joel1 Joel1 is offline
2005 Isuzu Ascender
Sandstone Metallic 4.2L I6 2WD
On mine, one of the washer fluid pumps cracked down the side and that's where all my fluid leaked from I refilled.... pull the air filter out then refill and try to ID where exactly the leak is. Flashlight is necessary. Easy to fix either way.
