Engine oil pump problem - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-04-2010, 02:24 PM
Soy Soy is offline
2002 Chevy TrailBlazer LT
Hi, My chevy trailblazer 2002 4.2l, after running about 30 minitues, when idle condition oil pump comes to zero. On acceleration it goes back to normal position. I changed oil 5W 30, fiilter. What could be the reason? Please help..
Old 07-04-2010, 02:32 PM
the roadie's Avatar
Most likely a bad oil pressure switch. In the I6 engine, the dashboard gauge is a lie. The computer creates a number of what it thinks the oil pressure should be, based on temperature and RPM. And then it displays that lie on the instrument panel.
But all it really knows is from a switch that goes on and off at 12 PSI. Switches fail more often than oil pumps.
Pull the switch and get a true oil pressure meter installed into that hole, and make sure the pump is OK. If it is, then just replace the switch. If you don't have the tools to do this, then you really need a mechanic to test the oil pressure. In case the oil pump *is* at fault, you want to know now, before it has a chance to fail on the road and damage the rest of the engine.
Old 07-04-2010, 04:32 PM
Wex Wex is offline
Senior Member
2006 Chevy TrailBlazer LS
This is a scan of a page out of the 02-07 Haynes trailblazer repair manual. Every time I see these oil pressure threads, I am amazed at the low pressures they can operate.
6 psi? Is that real or a typo?
Click image for larger version
2006 TB-LS 4x4. 4.2, 85K
Old 07-10-2010, 01:19 AM
02trailelecprob's Avatar
02trailelecprob 02trailelecprob is offline
Pewter Metallic 4.2L I6 AWD
sweet i need to repair my truck as well i will pick a switch up this weekend
Old 07-15-2010, 05:14 PM
brians02tblazer brians02tblazer is offline
Black 4.2L I6 2WD
oil pressure
having similar problem but only when towing trailer have replaced sender no help.am towing the trailer this weekend with trans cooler newly installed. have learned that oil sender is metric 16x1.5 thread and Pace Performance sells an adapter to 1/8 thread #ATM2268 did not order yet but that seems to be the only way to adapt to an extra gauge. What do you then do with sender wires??does computer need a reading to allow normal ops??
Old 09-01-2010, 05:40 AM
jakelock jakelock is offline
Summit White 4.2L I6 4X4
I'm glad I found this site! Great wealth of knowledge, I've recently been experiencing this same problem with my 02 Trailblazer. I was prepared to pull the oil pump and replace it until I read this thread. I'll try the sensor, TB clean and spark plugs and hope that clears it up! Thanks again all.
Old 09-01-2010, 10:58 AM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
I saw that too in my manual. Note that isn't even at idle that is at 1000 RPM! Weird. I'm not real familiar with modern GM V8's but I'd agree that seems awfully low. Maybe it should have been 16?
Perhaps someone with a GM service manual can comment.
Old 10-27-2010, 03:08 AM
Sensor seems to have done the trick! Thanks!
Old 04-24-2013, 10:54 PM
odieoner odieoner is offline
2004 Chevy TrailBlazer LS
Silverstone Metallic 6.0L LS2 V8 4X4
oil pressure
Im new to this forum thing so can somebody please help? When my thermast reaches halfway my oil pressure dips down to 0 then goes back up to the halfway mark. An it does this back an forth until I turn the car off.
Old 10-08-2013, 08:07 PM
lockhartboy407 lockhartboy407 is offline
2002 Chevy TrailBlazer LS
Black 4.2L I6 2WD
my trail blazer is doing the same boucing from almost 0 to 40 back and forth with no noise and when i idle my engine it stays norm but im planing on changing the oil pump just to be safe....... and i already changed the oil pressure switch and no difference but any body got any suggestions before i tare into this
