Usual oil leak locations on the 5.3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 07-08-2010, 10:39 PM
jkust jkust is offline
Senior Member
2007 Buick Rainier
Imperial Blue Metallic 5.3L V8 AWD
Hi all, my wife's Rainier started dripping oil last month at about 87,000 miles. There is a single drip each time you park it. It isn't quite bad enough to register on the dip stick yet. I am wondering what are the usual leak culprets on the 5.3. I got the oil changed today and they will charge $100 to remove the skid plate to diagnose the location of the leak with dye they add to the oil and you return a few hundred miles later. I didn't do the diagnosis yet.
Thanks
Old 07-08-2010, 10:51 PM
lhassebrock lhassebrock is offline
2002 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Sometimes there's some oil leakage from around the cam shaft postion sensor, I believe that's what it's called, but I don't know where it's located on the 5.3.
Old 07-09-2010, 07:07 PM
n0kfb n0kfb is offline
1901 NYqhn UquBJ
UiO9ourI9g Other AWD
I don't think the 5.3 liter V8 has a cam position actuator/sensor like the 4.2 six cylinder engine has.
I just had a leaky pinion seal on my front differential replaced due to a leak. It cost me about $250 to get this replaced.
-- Dan Meyer
Old 07-12-2010, 01:06 PM
Senior Member
2007 Buick Rainier
After getting the oil changed, it went from a drip to a small puddle underneath. Only drove home from the shop and backed it down the driveway one time. It's not the oil plug or the filter but looks like it's coming from the back of the engine so must just be coincidence not anything the shop did. You can't see any signs of leakage from the top of the engine anywhere when looking closely. Any thoughts as to what it could possibly be?
Old 07-12-2010, 01:12 PM
jacob789456's Avatar
jacob789456 jacob789456 is offline
Senior Member
2002 Chevy TrailBlazer LTZ
Red Jewell/Pewter 2-tone 4.2L I6 4X4
how about the rear main seal where the transmission bolts to the engine?
02' Trailblazer LTZ 4x4 with 3.73's & G80
Old 07-12-2010, 01:24 PM
Senior Member
2007 Buick Rainier
That is my fear. Sounds like some serious labor hours to fix a rear main.
Old 07-17-2010, 10:27 AM
Senior Member
2007 Buick Rainier
OK I am dropping the Rainier off at the shop on Monday. I'll give an update when I find out the problem. The shop I am going to is the same one that fixed the drive shaft seal when no one else would touch it (besides a dealer). They couldn't believe the shop that changed my oil suggested using a dye in the oil to trace the leak.
Old 07-20-2010, 05:21 PM
Senior Member
2007 Buick Rainier
Ok so I got the problem fixed. I couldn't believe it but the shop, whom I trust compared to the light maintenance shop that believed it was something much worse, said it was only a pinion seal on the front end. I insisted that the leak was coming from near the back of the engine, running down to the skid plate and dripping. They cleaned the underside of all oil, ran it and there were no more drips. I don't see how the fluid leaking from a leaky pinion seal can travel to the skid plate and drip down. I haven't been home to look and verify the leak did actually stop by seeing if there is a drip on the garage floor but I will check it tonight. In any event, the pinion seal installed was only $124. Once again I skirted the big repair bill on the Rainier.
