Removing A Pillars - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Interior
Interior Interior
Old 07-23-2010, 01:00 PM
SilverUnicorn's Avatar
SilverUnicorn SilverUnicorn is offline
2006 Chevy TrailBlazer LS
Removing A Pillars
Any photos? Need to pull the A Pillars on a 2006 LS with side curtain air bags.
Thanks,
Old 07-23-2010, 01:13 PM
goldelks's Avatar
goldelks goldelks is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
On the top of the A pillars you should see a little circle plug, use a flat screw driver to pop open that plug. In the hole from the plug will be a Philips head screw. Remove the screw. This will take the top of the A pillar off. After you have taken out the screw run your fingers down the inside of the A pillar and simply pop it off. There is one plastic clip holding it on about six inches from the bottom. Once you pop the clip out simply lift and pull the pillar out of place.
Hope that helps.
Old 07-23-2010, 01:14 PM
Perfect, thank you!
I thought it may be that easy, but usually when I think that things go horribly wrong, LOL
Thanks again for the fast response!!
Old 07-23-2010, 01:18 PM
goldelks's Avatar
Black 4.2L I6 4X4
No problem, if you need a picture reference I just made this. Glad to help.
Old 07-23-2010, 01:24 PM
Sweet, thanks!
CHris
Old 07-23-2010, 01:30 PM
goldelks's Avatar
Black 4.2L I6 4X4
Not a problem, your welcome.
