Fuse Box locations - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > OEM Issues
OEM Issues OEM Repairs & Problems
Old 07-25-2010, 06:45 PM
MLC MLC is offline
2004 Chevy TrailBlazer LS
Black 4.2L I6 2WD
Fuse Box locations
I bought my 04 Trailblazer yesterday.
While driving it at night I noticed that the dome lights dont come on when the door opens. and the indicatior for the door open doesnt come one either.
I just went out side to see if I could find the fuse for it to see if it is blown. started looking around and the only fuse box I found was under the hood. Where are the others or is that the only one?
Old 07-25-2010, 06:58 PM
Canadian Mike's Avatar
Canadian Mike Canadian Mike is offline
Senior Member
2004 GMC Envoy SLT
Under the seat of the rear passenger - driver's side.
Welcome to TrailVoy! Check out your owner's manual. If you don't have one, it's available as "pdf" in the Resources.
MyCardomain.com
Old 07-25-2010, 07:00 PM
pirateman's Avatar
pirateman pirateman is offline
2006 Chevy TrailBlazer LS
Welcome
Old 07-26-2010, 06:06 PM
MLC MLC is offline
Black 4.2L I6 2WD
cool, thanks
Just to save space and not start another thread since this kind of relates.
I have my driver side reverise light out, along with my dome lights and door open indicator. I changed my reverise light. nothing happened. still doesnt work. are all these compontents in the same circuit? I tried pulling the fuse for the dome lights and couldnt tell if they where blown or not.
Old 07-26-2010, 09:19 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
The dome lights might be turned off. Switch by the headlight switch.
If it is a fuse, it's #4, or #40 in the rear fuse panel
The backups are one the same fuse, so the fuse is ok.
The problem is with the rear assembly, a bad bulb, a bad circuit board, or a bad connector (of course, there could be a broken wire, but not high on the list).
The door open indicator may be a burnt out light in the dash.
Ray
You may not post new threads
You may not post replies
