2006 Trailblazer engine code PO506 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-15-2010, 08:51 PM
peteynac peteynac is offline
2006 Chevy TrailBlazer LT
I have an engine code PO506 on a 06 Trailblazer that says idle air control system rpm lower than expected.I can not pass emissions with out correcting this.If anyone has any information on how to correct this problem it would be much appreciated.
Old 08-15-2010, 09:18 PM
christo829's Avatar
christo829 christo829 is offline
2004 Chevy TrailBlazer LT
Two cheap and easy things to try:
1.Clean the throttle body.
http://forums.trailvoy.com/showthrea...ody+cle aning
2.Run some Seafoam through the system.
Do a search for P0506 and see what you come up with. That's P-zero-five-zero-six.
If you put in P-oh-five-zero-six, not as much will come up.
There's no IAC on these trucks, but anything that can affect the performance
of the air intake can contribute to this code. Buildup behind the throttle butterfly
can cause obvious rpm fluctuations, especially with the AC on.
How many miles on your truck? How's the maintenance?
Good Luck!
Old 08-15-2010, 10:48 PM
niteshiver's Avatar
niteshiver niteshiver is offline
2006 Chevy TrailBlazer LT EXT
Thumbs up p0506
i just had that code on my 06 tb.. i took off the throttle body and it was very dirty.. i used throttle body cleaner and put it all back together. then i used my code reader to erase the code and so far so good. took about an hour and cost me 10 bucks for the cleaner..
Old 08-15-2010, 11:14 PM
petevw's Avatar
petevw petevw is offline
2002 Chevy TrailBlazer LTZ
You DID have the battery disconnected for at least 30-40 minutes while you cleaned the tb, correct?
Old 08-17-2010, 05:53 AM
niteshiver's Avatar
no, i never disconnected the battery..
