Liftgate and Rear windshield wiper doesn't work! Help! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Appearance > Interior
Interior Interior repairs/modifications
Old 08-31-2010, 09:07 AM
Chicklet Chicklet is offline
2006 Chevy TrailBlazer LS
red 4.2L I6 4X4
I have a 06 Chevy Trailblazer and the liftgate won't unlock. The rear windshield wiper won't work either. i've tried using the clicker and that won't work either. i replaced the battery in the clicker and it still doesn't work. I have no way of opening the liftgate. can someone please help?
Old 08-31-2010, 09:40 AM
jsprewell's Avatar
jsprewell jsprewell is offline
2002 GMC Envoy SLT
Magnetic Red Metallic 4.2L I6 2WD
I currently have the same issues. most likely it's you LGM (liftgate control module). It will need to be replaced.
Also, to open your liftgate, get inside and there should be a circular cap in the middle below the window close to the floor. poop that open and there is a small lever inside. push/pull that and it will unlock. then you can open the liftgate from the outside again.
flickr
Old 10-19-2010, 03:41 PM
rustless rustless is offline
2003 GMC Envoy SLE
Black 4.2L I6 4X4
Make sure you look for damaged wires inside the rubber boot between the liftgate and the body.I have just repaired the same problem this way.
Old 10-24-2010, 11:31 PM
ksoldani's Avatar
ksoldani ksoldani is offline
2003 Chevy TrailBlazer LTZ
How can he check this boot if it won't unlock?
- Blue Township Fire/Rescue - KD0LDK - 911 Dispatcher -
'03 TB - 150k
Old 10-25-2010, 12:30 AM
the roadie's Avatar
Post 2 had the clue, as does the owner's manual.
You may not post new threads
You may not post replies
