Low volume growling from front end - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-01-2010, 08:04 PM
pejeeper pejeeper is offline
2005 Chevy TrailBlazer LS
Question Low volume growling from front end
Just noticed a low growl from the front end (I think). Low volume growl while straight and slightly louder on right turns, goes away on left turns.
My experience tells me right wheel bearing...agree?
I am going to get the tires balanced and an alignment first...I noticed a vibration after my last tire rotation 2 weeks ago and my steering wheel is ever so slightly tilted to the right as well.
05 TB with 55k miles. Can a shade tree mechanic accomplish this job without multiple Napa trips and beer runs?
Old 09-01-2010, 08:25 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Usually when the load shifts to the bad bearing, it complains.
Therefore, if it was the right bearing, the load gets transferred right when we make a left turn (weight always moves to the outside).
However, I had to change the right last fall. Like yours, it got louder when I turned right.
I have the left one (it might be a tire) complaining now, it gets louder on a left turn.
Ray
Old 09-01-2010, 09:11 PM
ChicagoDre ChicagoDre is offline
2004 Chevy TrailBlazer LS
Forest Green Metallic 4.2L I6 2WD
Sounds like a wheel bearing. Problem is, (and i experienced this), sometimes they both go but one "covers up" for the other one. So you'll replace one but still have the noise and it may even be louder; this was the case in mine. So be ready to replace both. Either way, theres a write-up on this site about how to replace the wheel bearing. You can definitely do it yourself, takes about an hour. Its even easier if youre RWD.
Old 09-02-2010, 02:59 PM
barniejekyl's Avatar
barniejekyl barniejekyl is offline
Senior Member
2005 GMC Envoy SLT
sounds like a wheel bearing assembly to me.....if it's loud when you turn right, then it's the right one.....mine was the left.....and it's starting to whine again with another 50k on it.......grrrrrr....gotta throw the cash at these trucks, but they are nice while they aren't begging for new parts.....
Old 09-02-2010, 03:47 PM
Thanks guys..oh and now I can add the blower resistor pack to the list...my #5 and #1 fan setting decided to quit yesterday!
Atleast that doesn't require jackstands!
Old 10-06-2010, 12:49 PM
chuck23796 chuck23796 is offline
2007 Chevy TrailBlazer LS
Graphite Metallic 4.2L I6 4X4
I also have a growling sound
Last week, I noticed a low volume growling sound coming from the front of my 2007 Trailblazer. My wife says she can't hear it but I drive the vehicle everyday and recognize the sound as different (not tire noise). The growling increases with wheel speed, not RPMs. There doesn't seem to be a difference in the sound when I turn the wheels. It is most noticeable around 40 MPH and coasting, before tire noise drowns it out.
My Trailblazer has 80,000 miles and is 4WD.
I'm thinking maybe the front differential rather than wheel bearings?
Old 10-07-2010, 10:25 AM
GM Customer Svc's Avatar
GM Customer Svc GM Customer Svc is offline
2009 Chevy Malibu
Red Jewel Tintcoat Other 2WD
Hello,
I do apologize that you are having problems. I see that your vehicle only has 80,000 miles and is a 2007. Sounds like it could be a powertrain warranty issue. If you would like me to verify that it is under warranty that way you can have the dealership take care of it, please let me know.
Geoff Allen
GM Customer Service
