| General If it doesn't fit in any other forum |
09-04-2010, 09:28 PM
2003 Chevy TrailBlazer LTZ Forest Green Metallic 4.2L I6 4X4
Tie Rod wrench sizes?
I am changing my outer tie rods and I don't have the right size wrench for the lock nut on the treaded end. Looks like a 21 MM. Anbody know what the size is and an easy way to break the nut loose? This things are really really tight. Thanks
09-05-2010, 12:34 AM
2003 GMC Envoy SLT Magnetic Red Metallic 4.2L I6 4X4
I don't know about the size, but spray the nut /threads with PB Blaster, or your choice of penetrating oil, at least a day ahead of time.
09-05-2010, 01:59 AM
Senior Member
2002 Chevy TrailBlazer LTZ Red Jewell/Pewter 2-tone 4.2L I6 4X4
I believe the two variants are 14 and 16mm and there is no way to tell which size you have without crawling underneath with a wrench.
02' Trailblazer LTZ 4x4 with 3.73's & G80
09-05-2010, 03:04 PM
2004 GMC Envoy SLT "Roadiemobile" Extreme Offroad Pewter 4.2L I6 4X4
That's for the threaded part of the tie rod end, not the OP's question. The lock nut is the same size for all model years I think, but I'm sorry I don't know exactly what size it is without looking. I'll go out and check it later because I also want to buy the proper wrench for the inner tie rod end while I'm at it. I've been using adjustables and that's not right.
09-05-2010, 04:47 PM
Senior Member
My bad, I was reading off of my cell phone and didnt see that, sorry. I also do not know what size the lock nut is, but when you find out, please post back.
09-05-2010, 04:59 PM
2002 GMC Envoy SLE Light Pewter Metallic 4.2L I6 4X4
09-05-2010, 05:50 PM
Thanks
It's an easy job with a big enough wrench. I got a 12 inch adjustable from my neighbor and with my 10 inch adjustable wrench on the inner rod nut it finally broke loose. The rest was a piece of cake. A hammer or two on the knukle and one blow to the post screw and they popped right out.
| Sponsored Links |
You may not post new threads
You may not post replies
