Rear Fuse Box - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-26-2010, 12:23 PM
papadakis papadakis is offline
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Rear Fuse Box
02 Trailblazer.
How do I get into it? Do I pull the seat up? Is it under the actual car?
Old 09-26-2010, 12:45 PM
chevtrlblzr's Avatar
chevtrlblzr chevtrlblzr is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
There's a strap that you pull so the rear seat (drivers side) will tilt forward. It's (the strap) between the seat and backrest - normally you can see the end of it - may have been pushed in but you can slide your hand in and get it.(where your money will go if it gets out of your pocket!)
Then you'll see the plastic cover for the fuse block.
- Carlisle Truck Nationals
Aug 5 - Aug 7, 2011 - Was Awesome
Old 12-11-2010, 11:27 AM
Vigilant444 Vigilant444 is offline
2006 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Pics
Found any good pictures on how to access the rear seat fuse box?
Old 12-11-2010, 12:03 PM
Wex Wex is offline
Senior Member
2006 Chevy TrailBlazer LS
Are you asking how to flip the 2nd row seat or how to remove the plastic cover that covers the fusebox? The seat is explained in post number two. To remove the cover, I believe it has three tabs. You pull the covers edge and then lift till you worked over all the tabs.
2006 TB-LS 4x4. 4.2, 85K
Old 12-11-2010, 02:05 PM
Black 4.2L I6 4X4
Actually was just looking for pictures (I'm a visual learner)...Thanks for the description though.
Old 12-11-2010, 02:34 PM
Black 4.2L I6 4X4
Found it
Got it. The release strap got the best of me. Thanks.
Old 11-26-2012, 01:08 AM
lkyl3l lkyl3l is offline
2008 Chevy TrailBlazer LT
Black 4.2L I6 2WD
what do i do if i don't have the strap to release the seat ? I have defintely checked everywhere..spent about 3 hours looking..on both sides for these straps and they aren't there...how do i get the seat to raise now ?
