Anything I need to know before replacing ABS sensor? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-10-2010, 10:12 AM
CHAVEZ CHAVEZ is offline
2009 Acura MDX
White Other AWD
Was changing lower ball joints and went to disconnect the ABS sensor and it snapped right off the hub. Yes...I now know to just unplug it near the frame and keep it plugged into the hub. I'm so frustrated that I did this. Anyway, so much for saving myself $$...I now have a $100 part to buy.
Just wondering it it's plug and play into the hub and that's it.
'04 TB LT
Old 10-10-2010, 11:10 AM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
Were you able to get the broke off piece out of the hub?
Old 10-10-2010, 11:18 AM
2009 Acura MDX
White Other AWD
Yes, It came out. There's still a little of the black plastic down in there, but I think I can get it out. I'm so mad that I did that I can't work on it right now. I need to calm down a bit and will head out later. We were going to take the TB on a trip this week, but will most likely rent something now.
I guess it's a little funny. Try to save some money and end up spending more. Oh well. I already ordered the part from Advance Auto...will hopefully be here tomorrow, but maybe Tuesday.
'04 TB LT
Old 10-10-2010, 11:31 AM
MAY03LT's Avatar
TrailVoy Guru
As long as you can get all the debris out, it should be a simple install.
Look at the bright side, you got it out, at least you don't have to buy a new hub
Old 10-10-2010, 11:46 AM
gmdude2004's Avatar
gmdude2004 gmdude2004 is offline
Senior Member
2009 SAAB 9-7x
Onyx Black 5.3L V8 AWD
SAVING UP FOR PCM FOR LESS NEXT !
And the capital for the 3" body lift!
Call me MUDDY WATERS.
Old 10-10-2010, 12:01 PM
2009 Acura MDX
White Other AWD
Good point. The part was only around $70, so not as bad as I thought.
'04 TB LT
Old 10-10-2010, 05:16 PM
2009 Acura MDX
White Other AWD
I have a scheduled appt. tomorrow morning for an alignment. If I cap over the sensor cavity with the broken sensor (so no dust gets in the hub) can I drive it without a functioning sensor? The new sensor may not get in until tomorrow or Tuesday.
'04 TB LT
Old 10-10-2010, 05:27 PM
MAY03LT's Avatar
TrailVoy Guru
Sure can. It would be the same as if the sensor developed an open circuit. It will prob turn the abs light on.
Old 10-11-2010, 12:58 PM
2009 Acura MDX
White Other AWD
Ok, replaced the sensor today and finished installing the lower ball joint. Went to take it to the shop for alignment and when I get to about 1-2 mph, almost to a stop, the ABS flutters a bit. Also, my wife was wondering why I was fluttering the brakes everytime I went over a bump (she was driving behind me). Of course, I wasn't, so I'm not sure what's up there.
There are not ABS lights on and everything else seems fine. Any ideas? Should I try resetting the ABS?
'04 TB LT
Old 10-11-2010, 05:59 PM
MAY03LT's Avatar
TrailVoy Guru
I'm not sure how far you can go without a scan tool. The only things that you can check is that the sensor is in properly and the tone wheel is in good shape. I have ran into tone wheels breaking and doing exactly what you are experiencing.
Other then that it will probably come down to someone getting into the abs module and reading the vss readings and taking it from there.
