4x4 issue - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > 4x4 Drivetrain
Old 10-11-2010, 06:10 PM
Jx4's Avatar
Jx4 Jx4 is offline
2006 Chevy TrailBlazer LT EXT
Black Granite Metallic 5.3L V8 4X4
4x4 issue
my 06 TB EXT, just jumps into 4x4hi by it self,
Old 10-11-2010, 06:19 PM
Cuda_Jim's Avatar
Cuda_Jim Cuda_Jim is offline
2005 Chevy TrailBlazer LT EXT
Graystone Metallic 5.3L V8 4X4
I'm not sure if this is a common issue but you should pull the appropriate fuse to disable 4x4 before the t-case is damaged.
Have you tried searching this site for your symptoms?..... there is a ton of info about our 4x4 system here.
Horse power = How fast you hit a wall
Torque = How far you take the wall with you
Old 10-11-2010, 06:45 PM
linneje's Avatar
linneje linneje is offline
2003 GMC Envoy SLT XL
Black 5.3L V8 4X4
This sure sounds like a wiring short, but I haven't read one like this before ... maybe someone with more experience on the forum could offer an alternate explanation. What I would do is (with the vehicle off) is cycle the selector switch for the 4wd through all the positions about 100 times back and forth to free the contacts from any corrosion that might have occured. Then fire it up and drive it and see if the problem persists.
Another thing that you could do is just replace the selector switch, as that is not something that is that expensive. If the problem persists, than at least you have eliminated a shorted or corroded switch.
Old 10-12-2010, 09:59 PM
Jx4's Avatar
Jx4 Jx4 is offline
Yeah, tried searching the site and nothing, will pull the fuse, thatís a great idea!
Old 10-12-2010, 10:02 PM
Jx4's Avatar
Jx4 Jx4 is offline
Will also try that. Thnxs 4 idea
Old 10-12-2010, 10:09 PM
gmdude2004's Avatar
gmdude2004 gmdude2004 is offline
Senior Member
2009 SAAB 9-7x
Onyx Black 5.3L V8 AWD
A wise man once said to keep a couple around the garage. I won't name names but his name rhymes with Roadie.
SAVING UP FOR PCM FOR LESS NEXT !
And the capital for the 3" body lift!
Call me MUDDY WATERS.
Old 10-12-2010, 10:19 PM
gmdude2004's Avatar
Senior Member
2009 SAAB 9-7x
The part number is gm # 15194913.
Old 10-18-2010, 11:18 AM
printjockey printjockey is offline
2002 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
Same type of Problem
Weird problem last night...found light on 4X4selector switch (2002) blinking on 2HI (where I always keep it) still drove ok. Made mistake of switching to A4wd then back (when car off) Started car - switch in 2HI, light blinking above, light solid above 4LO car in 4LO. couldnt get car out of 4LO. Pulled 4WD fuse from block under seat, nothing, pulled both drive train fuses nothing (I think) reinserted them..car stayed in 4LO, put switch in 2HI, sitting at signal, put car in neutral, and lo and behold car switch to 2HI, now drives OK..any ideas? Will this switch while driving?! What fuse will disable this but allow car drive in 2HI...Help!!!
Old 10-18-2010, 12:35 PM
linneje's Avatar
Black 5.3L V8 4X4
The switching back is probably easy enough to explain. If you want to get into or out of 4LO, I don't think that there is any other way than to be in neutral and stopped (or less than a couple mph anyway) ... you finally went into neutral and stopped, so it switched back. As to why it jumped into 4LO in the first place, that is a mystery ... perhaps a flaky TCCM since you have a 2002 (many were bad for that model year).
Old 10-18-2010, 01:45 PM
OK, bear with me, what is a TCCM?
