What's the best tool for cutting ABS plastic sheets? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > The Lounge > Everything Off-Topic
Everything Off-Topic A place to post pics, videos or to talk about anything, NOT RELATED to TrailVoys. (Please use good judgement)
Old 10-28-2010, 11:17 PM
CHAVEZ CHAVEZ is offline
2009 Acura MDX
White Other AWD
I bought a few ABS plastic sheets. Basically the same plastic you would use to make custom head unit cover plates and whatnot. I need to cut small pieces from the sheets, but I can't decide what the best tool would be that won't hack the plastic to bits, but will instead make smooth cuts. Some pieces will be very small so precision is also key.
Any ideas?
'04 TB LT
Old 10-28-2010, 11:21 PM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
Laser or hot wire.
Robert
Old 10-28-2010, 11:41 PM
DucatiSS DucatiSS is offline
TrailVoy Guru
1969 Rambler Rogue
Camo Other 2WD
How about a scroll saw like this.
Just set it to slow speed so you dont heat up the plastic.
Gone to a better place
Old 10-29-2010, 12:35 AM
Bill W's Avatar
Bill W Bill W is offline
2002 GMC Envoy SLT XUV
Summit White 4.2L I6 4X4
This might fit the bill - handheld, variety of available attachments and pretty cheap. I've borrowed one and it works pretty well but the jobs I've done didn't require precision cuts.
http://www.harborfreight.com/multifu...ool-67256.html
Old 10-29-2010, 11:33 AM
02TBFan 02TBFan is offline
2005 Chevy TrailBlazer LS
A dremel tool with a cutting blade would work perfect for that. You can get a variable speed one and they are super for small projects.
2005 Trailblazer LT 4x4 Olympic White
Old 10-29-2010, 12:56 PM
RDFABSREP's Avatar
RDFABSREP RDFABSREP is offline
2006 Chevy TrailBlazer LS
In the past, I've had the best luck with a small air-powered (handheld) reciprocating saw and fine tooth blade, or a Roto-Zip cutting "drill" bit. If it's a thin piece, you have also be able to use a sturdy set of tin snips.
Old 10-29-2010, 04:51 PM
bpaine bpaine is offline
2007 GMC Envoy SLE
cutting plastic
Put duct tape on one side, draw the form, cut and the edges will not be split, let us know.
Old 10-29-2010, 05:21 PM
jaraxle's Avatar
jaraxle jaraxle is offline
2002 GMC Envoy SLE XL
Onyx Black 4.2L I6 4X4
If the sheets aren't too thick I've used my soldering gun with a plastic cutter attachment.
"Real Hot Rods Don't Have Valve Covers".
Old 10-29-2010, 07:41 PM
2009 Acura MDX
White Other AWD
Thanks guys. I think I'm going to start out with the Dremel since I have one. If that doesn't work I'll look into that scroll saw. It's on the thicker side, so I'm not sure that melting will work well or the snips. I'll just keep going down the list of suggestions until something works I guess.
'04 TB LT
Old 10-29-2010, 08:19 PM
TrailVoy Guru
1969 Rambler Rogue
Camo Other 2WD
It would be best to find someone with a scroll saw like that. The good ones are not cheap, however if you know someone with one it would do quite well. I have that same model and it handles all sorts of tasks.
