Location of electrical grounds - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-12-2010, 07:58 AM
cbelke cbelke is offline
2004 Chevy TrailBlazer LT
Does anybody have a resource where I can find all of the ground locations for the Trailblazer? Looking to check each one and clean them up so I can rule out grounding as an electrical issue (dimming headlights). I have also heard that the Secondary Air Pump may have a bad grounding condition.
Old 11-14-2010, 11:51 AM
Wex Wex is offline
Senior Member
2006 Chevy TrailBlazer LS
Here are the ground listed in my service manual. Some you have to look for, others are clearly labeled. These are for the 4.2 and 5.3L engine. I have also included the short and long wheelbase. Be aware that the grounds may have changed from the early to late model years. Was about 20 pages I had to scan.
I hope I can fit them all in this post.
Hmm. It seems one of them got lost across my network. I will add the missing scan later on in the day.
Click image for larger version
ID:	14455   Click image for larger version
ID:	14456   Click image for larger version
ID:	14457   Click image for larger version
ID:	14458   Click image for larger version
ID:	14460   Click image for larger version
ID:	14461   Click image for larger version
ID:	14462   Click image for larger version
ID:	14463   Click image for larger version
ID:	14465   Click image for larger version
ID:	14466   Click image for larger version
ID:	14467   Click image for larger version
ID:	14468   Click image for larger version
ID:	14470   Click image for larger version
ID:	14471   Click image for larger version
2006 TB-LS 4x4. 4.2, 85K
Old 11-18-2010, 02:56 PM
Excellent!
Thank you very much. Now I have something to do this weekend.
Old 12-03-2010, 03:39 PM
Current Draw from somewhere
Hi Everyone. Some new developments in my quest to find out what the headlight flickering is about. Stopped by my mechanic and he did some load testing on the current battery and alternator and they both tested out as good. What he did notice was that with EVERYTHING turned off (engine, radio, blower fan, lights,key out of ignition) that there was still current draw of .68 amperes. He would accept .2 amps or less and said it would be time to start taking a look at bad grounds or other wiring issues. Anone have any ideas as to where to start?
Thanks!
Old 12-03-2010, 03:56 PM
Originally Posted by blckshdw View Post
Did you look at any of the grounds from Wex's manual?
Tracking down parasitic drains looks like it's always a PIA from the threads I've read. A lot of people start by disconnecting the OnStar module under the rear seat, as when that fails, it doesn't go to sleep like it should. Not sure how that would cause flickering headlights.
Another thing you can try, disconnect the megafuse in front of the underhood fuse block, and then see if there's still a draw or not. If the draw is gone, then you know the culprit is powered by the rear fuse block. If the draw remains, you know it's something powered by the front one. Looking in your manual, you can figure out what those items are, and troubleshoot further as you see fit.
Good starting points. Thanks.
I did look at the few grounds I could reach, all seemed clean and tight. Wex's diagrams are great. there is a TSB for a ground modification (new ground post and nut somewhere on the frame) for the TBlazers but I'm not sure of the location of the ground. I need to find out more about that TSB. The number is 10-08-45-001A and came out on June 6th, 2010.
Thanks!
Old 12-03-2010, 05:28 PM
Bill W's Avatar
Bill W Bill W is offline
2002 GMC Envoy SLT XUV
Summit White 4.2L I6 4X4
Wex - thanks a lot . That's a keeper to tuck in my trailvoy file for future reference.
Old 12-04-2010, 08:45 AM
Wex Wex is offline
Senior Member
No problem at all. Even if one is not having a ground issue, its informative to be become familiar with your vehicle platform.
Old 12-04-2010, 08:11 PM
Ok. Followed the recommendations of disconnecting the megafuse in the fuse block (engine compartment) and had Advanced Auto run the electrical system test and the current draw was at zero. Down from .68 amps from the first test.
Spent a couple of hours tracing wires and removing/replacing fuses, removed the OnStar fuse as well, to see if there were any differences but alas, I did not find any thing that stuck out and said here I am. Anyone have any recommendations for troubleshooting an electrical issue like this with minimal equipment? I hate spending the money to go to a dealer and have them figure it out, if they even can.
Thanks!
Old 01-12-2016, 03:46 PM
mmarx82's Avatar
mmarx82 mmarx82 is offline
2005 Chevy TrailBlazer LS
Charcoal 4.2L I6 2WD
I know this is old but did you ever fix it?
