[SOLVED] help turn signal blinker driver side blinks fast - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-23-2010, 04:40 PM
smalltownrp830's Avatar
smalltownrp830 smalltownrp830 is offline
2002 Chevy TrailBlazer LS
Victory Red 4.2L I6 2WD
i just replaced the headlights with some newer ones because mine were cloudy. i had already put them back on and the grill back on when i noticed that the drivers side started blinking a whole lot faster. i swapped taillights and they were doing the same thing. so its not the rear. then i put my old headlight back on and also does the same thing. i checked the bulb in the front and it seemed fine. also checked the fuses and nothing seemed burnt. any suggestions on what i could be????
Old 11-23-2010, 04:51 PM
bedbug's Avatar
bedbug bedbug is offline
2003 Isuzu Ascender
Nordic Blue Metallic 4.2L I6 2WD
Fast flashing turn signal USUALLY means a blown/loose bulb. Sometimes even the dash, but mostly exterior is the target to look at.
Old 11-23-2010, 04:52 PM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
usually a bad bulb or ground!
Old 11-23-2010, 04:58 PM
hatchet669's Avatar
hatchet669 hatchet669 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
as said... turn on turn signal and see if any is out... 2 in the front and 1 in the back...
Old 11-23-2010, 05:30 PM
Boricua SS Boricua SS is offline
Any hyperflashing for the majority is due to a bulb being burnt out...
Old 11-23-2010, 07:25 PM
hatchet669's Avatar
TrailVoy Guru
uhhh just thought of something... u said new headlights... are they aftermarkets? adid u put LED bulbs in? LED bulbs will cause hyper flash as well...
Old 11-27-2010, 03:05 PM
im an idiot...i swapped the whole headlight but not the bulbs in the front. it was the dumb turn signal bulb. thnx to those who responded
