Steering wheel lock and ABS pulsing - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-01-2010, 07:02 PM
hardtrailz400's Avatar
hardtrailz400 hardtrailz400 is offline
2006 Backwoods Edition Super Offroad Trailblazer
Captain Insano 4.2L I6 4X4
Had some issues along the lines of some others. Like others I get the traction control light and stabilitrac light sometimes. Goes off after restart but happens fairly regularly when it is cold. That i can deal with, but in the past couple weeks I have had the ABS kick in at very slow speeds. I can feel it pulse in the pedal at very random occasions. Thought it may have been due to replacing hubs and sensors, since I had not reset the computer. It had not happened in a couple days, but last night I unhooked the battery and left it off for a couple hours and restarted it. No lights. This morning, no lights, but 12 miles down the road in downtown traffic I stop at a light and left off the brakes to roll a bit closer to car in front of me and when I hit the brakes...used no throttle to roll forward...the pedal pulsated again. Absolutely no reason for the abs to engage.
Then after work I get in the truck, start it and idle for 30 seconds, no lights. Pull forward 12 inches and try to turn steering wheel right..LOCKED and then lights come on, feel the wheel pop and I can turn. Pull out into aisle of parking garage and restart. No lights. Drive home and no issues or lights.
Check wires and everything looks good. Ignition switch is only 6 months old. Battery is new. Any ideas for me to try or to check? I am getting no lights other than stabilitrak and trac control. I did order another abs sensor wire, but not sure which side it would be or if that would really be it since it seems that the real issue is something in the steering.
Help!
Midwest Chapter: Indiana Rep
The computer beat me at checkers once, but it was no match for me at kickboxing.
Old 12-02-2010, 08:12 AM
This morning...
Start truck, no lights everything seems good. Grab wheel and it is locked again. Shut off truck. Restart. No lights but steering locked. Back up 30 feet out the drive going over 6 inch curb to see if it unlocks wheel. Nope. Pul back and forth over curb a couple times. Still locked. Pull in driveway shut off and restart. Still Locked one arm cant turn wheel, use both and it "pops" loose and steering feels a bit loose but wheels are turning. But now both lights are on. Back out and drive halfway out the neighborhood. Shut off truck. Start truck and no lights and steering is fine.
I plan to check fluid again. Was fine and no leaks to be seen. I also have the package with the plug-in for cold weather so can try that overnight, but wont help in parking garage at work.
Any ideas?
Old 12-02-2010, 08:22 AM
bartonmd's Avatar
bartonmd bartonmd is offline
Basic Vendor- Skid Plates
2007 Chevy TrailBlazer LS
hmmm... I think you've got 2 seperate issues...
Usually, the low speed ABS activation is a sensor issue... My grandpa's and dad's trucks did that when there was crap in the reluctor wheel of the wheel speed sensors, causing a weaker signal from the hall effect sensors (which is already weak at low speeds)...
The steering wheel lock seems like an ignition switch, or ignition switch connection issue... The steering wheel lock thinks the ignition is still turned off...
Mike
ETA: Just for grins, you might clean all of your body grounds, and put dielectric grease in them... Bad grounds could cause both of those things...
The GB ended, but PM me if you want one!
GB also ended, but PM me if you want these!
Old 12-02-2010, 08:37 AM
I can swap the passenger sensor wire with the new one coming today since it was the last sensor I messed with. May just try unpluging and greasing and repluging in case dirt was in there. I do have a bit of dirt under and on and in my truck.
The ignition switch has been replaced and I keep one with me, but it starts perfect and I dont have the other issues with it.
Clean the grounds...Be a bit of work with all the crap coating everything, but should prolly be done anyway. You know how nice and freindly the weather is right now too.
The other issue you mentioned...I will try to find a way to warm up the input long enough to evaporate anything in there..
I guess I have motivation to finish cleaning the garage to get it inside now.
Old 12-02-2010, 08:41 AM
bartonmd's Avatar
Cool, let me know how it goes...
Mike
Old 12-02-2010, 12:53 PM
regulator1175 regulator1175 is offline
2002 GMC Envoy SLT
Onyx Black 4.2L I6 4X4
When you replace/rotate the abs sensors take a flashlight and inspect the inside track of your hub. You should be able to visually tell if there is a build up of dirt or grease preventing a good reading of the sensor.
If I remember correct didnt you crack the head on one of the sensors when putting it back on, or was that why you had to replace the passenger side? That could be the issue as well.
I agree with Mike, I think you have two separate issues happening. I have no knowledge of the steering system though. Thankfully I have never had an ignition switch issue. Of course now that I said that mine will go out next week.
Good luck, and as always if there is anything I can do to help let me know.
Old 12-02-2010, 01:50 PM
2003 GMC Envoy SLT
I don't understand how the steering wheel would lock.
We don't have locking steering wheels. Is it possible you have a bad axle shaft binding? Or water in the PS system that causes ice to plug a valve?
Old 12-02-2010, 04:07 PM
bartonmd's Avatar
I guess I hadn't ever noticed...
The thing Kyle and I had been talking about was the fact that when he went from the 2" body lift to the 3", he got the new steering boot, but didn't put it on... I'm thinking he's got some water in the pinion input from the steering shaft, that's freezing since it's gotten cold in the last few days...
Mike
Old 12-08-2010, 09:53 AM
Doesnt look like there is anything in the boot seperated by the lift. It feels like there is a seal or bushing right up near the steering wheel or in the firewall that is twisted or frozen and once warm lets the wheel turn as normal, but when super cold for awhile it either refreezes or stiffens up. It has been wheeled pretty hard and nothing would really surprise me, but I dont have a good place to work on it in this weather. Asked a good mechanic and my buddy that does body work and neither has a clue. My buddy got to feel how it was stuck after it sat at his place for awhile and he said it feels like it is right in the column, but adjusting the tilt changed nothing.
Not sure if this allows for more ideas or if anyone knows how the steering goes through the firewall(I never paid attention) but any ideas and advice will be appreciated.
