[SOLVED] spongy brakes at slow speed - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-04-2011, 07:14 PM
muppit muppit is offline
2005 Chevy TrailBlazer LS
Graystone Metallic 4.2L I6 AWD
i have a intermitten brake issue for some time brakes are spongy or pedel goes to the floor at slow speed all the brakes are new(less than 100 miles
) and i still happens both in forward and reverse im thinkin its theabs sensors on the front hubs but not sure because you dont get the pulsation on the brake pedel
Old 01-04-2011, 08:51 PM
barniejekyl's Avatar
barniejekyl barniejekyl is offline
Senior Member
2005 GMC Envoy SLT
did you change the brakes, or did you have a shop do it...? if a shop, take it back and have them fix it right......check the fluid and top it off, and bleed the brakes....if the pads were installed correctly, this should correct the problem..
Old 01-05-2011, 03:53 AM
bearhunter's Avatar
bearhunter bearhunter is offline
Sounds like you might have some air in your brake lines.
Old 01-05-2011, 05:17 AM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
After bleeding the brakes, your pedal will still be somewhat spongy. Some members reported that after getting on your brakes and letting the ABS kick in helps bring that high pedal feel. This was true for my car as well. Might want to give it a try.
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 01-05-2011, 06:01 AM
Hal's Avatar
Hal Hal is offline
2003 GMC Envoy SLT
Polo Green Metallic 4.2L I6 4X4
Mine as well. I had the spongy brake pedal until one morning on my way to work I had to really hit the brakes. The ABS kicked in and have had about 1/2 inch of travel since.
You Ain't Heard Nothin Til You've Heard a Holley 750's Secondaries Suckin Air.
Old 01-05-2011, 04:55 PM
i should have prased this post differantly i have a good pedel most of the time the truck stops well at speed but if you just go slow and try and stop it ocassionally is spongy and goes to floor for instance back out driveway and try and stop its got a soft pedel or if you do a nice slow roll in forward same thing but never all the time . under normal driving stops fine i put the brakes on the have been bleed nothing is sticking calipers function good slide pins are free and well loobed . its either abs issue or master cylinder just not sure
Old 01-05-2011, 08:57 PM
Gevans17 Gevans17 is offline
2004 Chevy TrailBlazer LS
Dark Green Metallic 4.2L I6 2WD
Spongy brake pedal
Assuming no air in line and brake hoses are all good, Chevy brakes tend to be a little on the spongy side. I have 2002 and 224 TBs, and both have a spongy pedal compared to my Ford Expedition.
Old 01-13-2013, 07:29 AM
-crash- -crash- is offline
2002 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Question Spongey Brakes
I have an 02 TB with spongey brakes fresh fluids vacuum bleed. NO air in lines. My ABS light is on and non functional.. is this my problem is the modulator valve(s) sticking ? how do I fix this ? thanks for your time
-crash-
