2004 gmc envoy cylinder 6 misfire - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > The Lounge > Introductions
Introductions Welcome to TrailVoy.com! Tell us about yourself, your vehicle, mods, location etc. (no tech questions)
Old 01-08-2011, 08:45 AM
tulane tulane is offline
New Member
2004 GMC Envoy SLT
silver 4.2L I6 2WD
I took my 2004 envoy, 6 cyl, 117,000 miles in for new plugs and fuel filter. I purchased the vehicle new. I have never had any problems with this vehicle until I had the sparkplugs changed. Now it indicates a P0306 misfire at cylinder 6. The vehicle idles roughly in neutral and more roughly in drive with the brake depressed. Fuel economy has decreased 25% since the plugs were changed. The engine always starts right up and I have not noticed it missing while driving but only at idle. It also has never stalled nor hesitates. The coil packs have been switched around but still throws this code out. I see no evidence of any leakage under the vehicle or from valve cover. I took the vehicle in and the mechanics were hesitant to remove the plug from the cylinder (6) as it was abnormally tight. Finally had this done and the plug showed evidence of cross threading. They did a "tap" and replaced plug but still threw out the same code. It still shows only this code and nothing else. HELP!!!!
Old 01-08-2011, 09:02 AM
foarob1 foarob1 is offline
2002 Chevy TrailBlazer LS
you may have a injector sticking. Injectos will cause more of a miss at idle if the are sticking and a spark problem will usually be more appanent under a engine load. if you can get to that injector (not sure if you can) try puting a flathead screwdriver on it and tap it with a hammer (not to hard!!!!) to see if you can get it to start flowing if it is sticking . If not I would try running 2 good bottles of injector cleaner through it the cheveron with techron black bottles are the same as the gm stuff. Run your fuel down to less than quarter of a tank put the injector cleaner in and get on the gas to try to blow out any crud.
Old 01-08-2011, 10:57 AM
the roadie's Avatar
Who did the work? Somebody who knows trailvoys?
The plugs MUST be Delco 41-103 iridiums. Other brands have been reported as causing problems.
Old 01-08-2011, 06:55 PM
ghoster ghoster is offline
2011 Chevy Tahoe
Mocha Steel Metallic 5.3L V8 4X4
You sound like a delco salesperson.
Not that you are wrong, you are absolutely correct. Still sound like a salesman though.
Old 01-08-2011, 09:03 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
If the problem appeared (and it sounds as though it did) as soon as the plugs were changed, then it IS related to that change.
If the coils were swapped and the problem stayed with @6, then it may be the plug, or it might be the primary voltage connection (the electrical connector on the coil).
It might also be the secondary (high) voltage boot not being properly seated on the plug.
Of course, the question of, do you know which plug is # 6, needs to be asked.
It is the one next to the firewall, and the hardest to get to.
And sure, it could be something else, but check the simple and obvious first.
Ray
Old 01-08-2011, 09:55 PM
christo829's Avatar
christo829 christo829 is offline
2004 Chevy TrailBlazer LT
Make sure they used the AC-Delco 41-103s..
If they cross threaded one, they may also have damaged one. If they didn't do
the re-thread properly, you may not have a good seal at that plug. If they were
having problems dealing with that #6 plug, they may have damaged the coil electrical
connector, or not put it back on properly.
And are you sure they replaced that plug, instead of just pulling it, cleaning those
threads and putting it back? Just wondering.
Good Luck!
Old 01-18-2011, 09:19 AM
New Member
2004 GMC Envoy SLT
silver 4.2L I6 2WD
2004 envoy slt 6 cyl
they did a tap and replaced all spark plugs. They said they found spark plug 5was loose and didnt look right and replaced. The vehicle has stopped shaking in neutral and drive with the brake depressed. I drove the vehicle for a week with no problems. I put a can of seafoam in the gas tank. The ses light popped back on yesterday but no shaking. This is really frustrating.
Old 01-19-2011, 08:32 PM
New Member
2004 GMC Envoy SLT
silver 4.2L I6 2WD
tulane/2004 gmc envoy slt 6 cyl
i posted incorrectly initially. Purchased this vehicle new and it has been problem free until recently. My speedometer went bezerk but now has reset itseelf back to normal. More recently (see other posts) I have had a misfire in cyl 6. Have changed spark plugs and fuel filter. Took to shop and they think it is a bad intake valve. Th the car does not stall but misses at idle. Gas mileage has been reduced by 25%. Discoloration in cyl 6 sparkplug.
Old 01-19-2011, 10:02 PM
christo829's Avatar
Not sure what it is with shops and valve issues lately.
Kinda doubt it's valve related. Still think it's more directly related to the plug work
you had done. A poorly reseated coil pack on 6 could mean it isn't firing at full
strength. If you can get a picture of the plug, might be able to figure out what's
happening, though I suspect it's mainly just unburned fuel and some buildup from the
crankcase recirculation. If there's enough buildup, it could be causing the valve to not
seat cleanly, but a few fuel treatments might clean that up if that's the case.
So, you had the plugs and fuel filter done...not the coils? Do you still have a CEL?
If so, is the code still for cylinder 6, or has it gone to random misfire? Did the shop
actually fix the plug and swap coils around, or was that part of the mispost? You may
want to see if you can get a closer look in to the #6 plug well, and see if there's any
blow-by.....that plug might still not be threaded in properly, or the re-thread may be
leaking.
Really still leaning towards the problem being with that coil and the overall plug job,
which sounds like it wasn't done well. Yes, it could be a valve, but *much* more likely
to still be a problem in the plug/coil.
Leaning towards the speedo problem being a flaky stepper motor. If you ever see it
stop above zero when you shut the truck off, and then stick and jump, or never zero out
and just go up from wherever it was stuck, that's usually the stepper motor.
Cheers-
Old 01-29-2011, 04:25 PM
Thalwandi27 Thalwandi27 is offline
2002 Chevy TrailBlazer LT
Black 4.2L I6 4X4
similar miss on I6
I had a similar miss at idle. The plugs are new delco. Had the mechanic put a scanner on and it showed that #1 was missing. Swapped coils with #2 and then the miss went to #2 cylinder. Put a new coil on #2 and scanned again. #2 kept showing a miss. Any ideas.
