4 Wheel drive won't engage - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 01-12-2011, 05:11 PM
llparker01 llparker01 is offline
2005 GMC Envoy SLT XL
Black 5.3L V8 4X4
I have a 2005 Envoy XL Slt 5.3L..I notice that when I switch to A4WD or 4Hi the light stays on steady but I realize its actually in 4Lo. I have seem some suggestions about pulling a fuse or tccm and re install it. can anyone else give me some suggestions before I take it to a dealership. this couldn't happen at a worse time I could really use it for this atlanta snow/icey roads.
even though its stays in 4Lo no matter what I select 4Hi or A4WD its better than nothing but, I could really use 4Hi/A4WD.
Thanks for any suggestions
spelling error-I meant engage
Old 01-12-2011, 05:15 PM
mika's Avatar
mika mika is offline
2002 Chevy TrailBlazer LT EXT
Are you in 4lo all the time or can you get it to 2hi? If 2hi and your only other option is 4lo it could just be your selector switch.
Old 01-12-2011, 05:23 PM
darknight's Avatar
darknight darknight is offline
2005 Chevy TrailBlazer LS
Black Granite Metallic 4.2L I6 4X4
it maybe the motor to some one will chime in soon that can give you more help ROADIE lol have you taken it in to be seen yet or do you plan to do it ur self
definity MT's MarkMC 2.5 susp. custom lift Light bar JL audio Equipment 6k hids custom bumpers to come
Old 01-12-2011, 06:02 PM
Black 5.3L V8 4X4
4 wheel drive won't engage
2hi works fine but if I select a4wd or 4hi whatever I select lights steady but I can feel its actually driving in 4lo because I can only drive at a slow speed unless I switch back to 2hi
Old 01-12-2011, 06:05 PM
Black 5.3L V8 4X4
thanks for the response..I'm actually from Hampton VA and worked at Langely until I moved. anyways 2hi works fine but if I select a4wd or 4hi the selection I choose lights up like everything is normal but I can only drive at a slow speed(tells me I'm in 4Lo) unless I switch it back to 2hi then everythings normal.
Old 01-12-2011, 09:15 PM
the roadie's Avatar
First time I've heard of this exact issue. Unless you're an advanced DIY mechanic with access to the schematics and good electrical skills, I would take it to the dealer to diagnose. It may be the TCCM or the encoder motor or some odd internal breakdown in the transfer case. Sorry I can't be of more help.
To confirm you're in 4LO, the RPMs for any given road speed would be 2.7 times as much in 4LO than 2HI. Can you do the experiment to go 10 MPH and 20 MPH and write down your RPMS in 4th gear. Only do this on a slippery surface because you can't use 4HO or 4LO on pavement.
