Turning off Stabilitrak - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-22-2011, 12:44 AM
DGenerate23's Avatar
DGenerate23 DGenerate23 is offline
2006 Chevy TrailBlazer LT
Black 4.2L I6 4X4
I have searched all over this forum and can't find an answer. I have tried everything the maual tells me to do to turn my stabilitrak off Parked and moving. i even held the button in for my entire lunch one day which is 30 minutes and cannot get it to shut off. can someone give me a step by step instruction ob how it should be done i know it works cause im always getting the little message in my D.I.C that stabilitrak is active. someone please help me
Old 01-22-2011, 12:56 AM
RedEnvoyDenali's Avatar
RedEnvoyDenali RedEnvoyDenali is offline
Senior Member
2006 GMC Envoy Denali
Magnetic Red Metallic 5.3L V8 4X4
All I do for mine is simply push and release the button under your thumb on the left side of the gear shift lever. The cluster light then comes on telling me the Stabiltrak is OFF.
Don't know if there is any other way to disconnect.
Old 01-22-2011, 01:02 AM
Black 4.2L I6 4X4
I guess ill have to try again as soon as i get it back from the shop early next week
Old 01-22-2011, 10:23 AM
Wex Wex is offline
Senior Member
2006 Chevy TrailBlazer LS
Mine I think I push the button, the traction control off icon comes on. Then hold the button for about three seconds and then the stabiltrak shuts off.
2006 TB-LS 4x4. 4.2, 85K
Old 01-24-2011, 10:01 AM
fletch09's Avatar
fletch09 fletch09 is offline
2009 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
IIRC some one else could not get theirs to turn off. turned out to be a loose wire under the shift boot. check that also.
Old 01-24-2011, 10:12 AM
Wex Wex is offline
Senior Member
I tried mine yesterday. One push made icon come on solid. This I assume is traction control disabled.
Or hold down button for several seconds and made an icon flash. This I assume is stabilitrak off. I did not have to go through the second step like I previously mentioned. I think that second step how I read it in the user manual tho.
I believe it is the same icon behavior when you goto into 4Lo. 4Lo should disable stabilitrak as well.
Old 01-24-2011, 10:22 AM
fletch09's Avatar
if you have it , the D.I.C. should tell you that the traction control is off, and that the stabilitrac is off. it does on my 09. maybe not on the 06.
Old 01-24-2011, 09:05 PM
Black 4.2L I6 4X4
i have the D.I.C. and no matter how long i hold the button with my TB in park or neutrel i can not get the TC or Stabilitrak to shut off i think when i get it back from the body shop on wed im going to tear into the shift boot and see about that loose wire
Old 01-24-2011, 09:50 PM
fletch09's Avatar
i am able to turn those off in any gear. def. look for a loose or disconnected wire. if you cant find anything, talk to a dealer, if out of warranty, may be covered since it's a safety issue and part of drive train
Old 09-22-2014, 05:32 PM
najohnson86 najohnson86 is offline
2007 Chevy TrailBlazer LS
Graphite Metallic 4.2L I6 AWD
Mine I think I push the button, the traction control off icon comes on. Then hold the button for about three seconds and then the stabiltrak shuts off.[/QUOTE]
Do you hold the button while in drive or park?
