OK to replace just 2 tires..?? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-09-2011, 11:22 AM
davenay67 davenay67 is offline
2002 Chevy TrailBlazer LTZ
My wife picked up a nail in the sidewall of her TB tire (rear) this morning. Tires are still fairly well endowed as far as tread is concerned, I would guess 7/32 is left.
My question is whether I can just replace both rear tires, or do I need to replace all 4. We use AWD only in bad weather, and never use 4WD.
I don't want to dump $$$ into tires, but I don't want to overly stress the TB diffs either.
Dave.
126,xxx miles.
Stock (including some parts that probably shouldn't be stock/original by now).
Old 02-09-2011, 11:58 AM
bromanjr's Avatar
bromanjr bromanjr is offline
Senior Member
2004 GMC Envoy SLT XUV
Indigo Blue Metallic 5.3L V8 2WD
My advice is yes, but always put newer tires in the front. rotate when the wear is fairly even or front are more worn. the fronts usually wear faster (except SS's ) and they will "catch-up" with the wear on the rears over time.
Another fun fact is that the least worn tires on the front can lead to less hydroplaning.
my
182,000 and counting. Superchips 2914 Tune, NAV upgrade.
Old 02-09-2011, 12:47 PM
hardtrailz400's Avatar
hardtrailz400 hardtrailz400 is offline
2006 Backwoods Edition Super Offroad Trailblazer
Captain Insano 4.2L I6 4X4
Should be fine to only do two.
Midwest Chapter: Indiana Rep
The computer beat me at checkers once, but it was no match for me at kickboxing.
Old 02-09-2011, 07:08 PM
Simon01's Avatar
Simon01 Simon01 is offline
2005 Chevy TrailBlazer LS
Superior Blue Metallic 4.2L I6 4X4
2 is fine. If you get a different brand of tire, try to keep 2 of the same on the front and 2 of the same on the rear. If you put 2 different tires on the front, you might get a pull (steering wheel off center).
Old 02-09-2011, 08:05 PM
DanD DanD is offline
2003 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
Actually, new tires should ALWAYS go on the rear of any vehicle, even if you've got a front wheel drive car. Most tire places won't put new tires only on the front or will make you sign a waiver. The reason for this is to prevent fishtailing during braking or cornering in low traction conditions. Here is a link to the subject at tire rack. You can also find the same information at popular mechanics, rubber manufacturer's association, etc.
http://www.tirerack.com/tires/tirete....jsp?techid=52
Old 02-09-2011, 08:12 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
That is correct Dan...........Always on the rear.
Ray
Old 02-09-2011, 09:04 PM
bigredtank's Avatar
bigredtank bigredtank is offline
2006 Chevy TrailBlazer LT
blood red 4.2L I6 4X4
my
false. new tires should always be placed in the rear even in a front wheel drive vehicle. you do this to avoid hyrdoplaning in wet or snow weather traction. harder to compensate for over steer when the back end looses control then it is the front.
as far as the 2 or 4. always best to get 4 but since your truck isnt awd just 4awd and your other tread has less then a 4/32 difference it wont make a difference or do any damage to a transfer case as it would like a suburu or audi thats allwheel drive ALL the time.
my from yours truly Discount Tire Co. Supervisor! B.R.Tank
Old 02-09-2011, 09:17 PM
ahabofthepequod's Avatar
ahabofthepequod ahabofthepequod is offline
2008 Chevy TrailBlazer LT
Black Granite Metallic 4.2L I6 2WD
As the noted philosopher Elmer Fudd used to say, "Be Vewy, Vewy Carefuw" (Be very very careful) doing this.
What people need to understand is - just because you replace a Michelin "ALL TERRAIN" (P245/75R16) tire on your truck with a Goodyear or MOTO tire that has the same size "P245/75R16" on it there may be a measureable difference in the actual tire size.
Even with the same tire manufacturer, two different tire models may also be marked as the same size but may actually be different sizes.
When I looked for tires I thought people were pulling my leg about this so I went into SAM's Club (Where you can actually look at the tires you buy) with a measuring tape and found as much as a 1/2" differencee in tire height.
Differences in tire heights can cause a myriad of issues with the newer cars/trucks with all the new computer controlled items.
Unless you're replacing all 4 at once, make sure you replace a Uniroyal "Tiger Paw" with a Uniroyal Tiger Paw, etc...
Old 02-09-2011, 09:29 PM
bigredtank's Avatar
i agree but only to a certain degree.
ok obviously if you replace an AT with a regular street tire in the same size theres gonna be a difference in size. only because the m/t come with 14 to 16/32 in which a highway tread probably start with 12/32. furthermore, when buying tires your always for the most part gonna stick in the same catagory as far as quality. an entrylevel 205/65/15 is going to be smaller then a premium quality michelin in the same size.... why? more ingredients in the tire. reinforced sidewalls, stronger beads. 12/32 instead of 8/32. integrated tread sipe, stronger steel belts, and other different features and benefits. so when saying you get what you pay for.... with tires thats really how it is. so do your homework before buying. and many tire shops are more then willing to show you their inventory on request.
Old 02-09-2011, 10:35 PM
bromanjr's Avatar
Senior Member
Well, I learned something new, I searched a few articles and found the same recommendations you guys wrote about, thanks for the correction guys.
DanD, the link you provided did not take me to Tire Rack and the article, but I googled and found a few others.
