Air suspension frozen? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 02-11-2011, 11:26 AM
kingpin72 kingpin72 is offline
2004 GMC Envoy SLT
Summit White 4.2L I6 4X4
This is my first post so let me first say Hello! and thanks for having me. I live just south of Toronto, Ontario, Canada. It is extremely cold here, and during this cold-snap, my air suspension has ceased to operate. Is it possible for the system to freeze up? Any ideas to fix the issue?
Thanks in advance for any help.
Old 02-12-2011, 09:23 AM
ylw750 ylw750 is offline
2004 Buick Rainier
Liquid Silver Metallic 4.2L I6 AWD
I had that happen to me once. I turned on the pump with the switch in rear compartment of truck and the suspension started lifting. Lucky I guess but it worked.
Old 02-12-2011, 09:45 AM
JuicyK's Avatar
JuicyK JuicyK is offline
2002 Olds Bravada
Pewter Metallic 6.0L LS2 V8 AWD
I would try the interior switch.
Could be just as easy as a fuse, or as bad as moisture in the pump its self.I am not super knowlegeable on the Air ride.
02 Bravada, G80, 3.73, Pewter, 5500k 35w Low beams. :
Grandma Made Turkey for the NATION period com.merical
Old 02-21-2011, 12:47 PM
2004 GMC Envoy SLT
Thanks guys
I think it was water in the system. I parked it inside the shop for a couple of hours at work to let it thaw and low and behold the rear rose from the ashes. Now if the temp will just stay above freezing I won't feel like I'm driving a John Deere to work.
Old 02-21-2011, 06:49 PM
Canadian Mike's Avatar
Canadian Mike Canadian Mike is offline
Senior Member
2004 GMC Envoy SLT
Keep a watch on the entire system. Mine started to act up, approx. 1 year later, I replaced my compressor with "Arnott's"
BTW - Welcome fellow Canuck, to TrailVoy!!
Old 02-23-2011, 04:05 AM
2004 GMC Envoy SLT
Thanks Mike,
Nice to be here. I'm holding out hope that we'll be above freezing for a few days so I can check thiongs out.
