[SOLVED] '05 TB - How do you loosen the fan clutch nut? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 02-21-2011, 05:15 PM
05traleblazer 05traleblazer is offline
2005 Chevy TrailBlazer LT
Graphite Metallic 4.2L I6 2WD
I'm trying to replace the water pump on my '05 TB and for the life of me, can't find a way to loosen the fan clutch nut that threads on to the water pump shaft without the water pump shaft turning. How does everyone get past this step???? My pump is shot and I can't drive it until I get it replaced. Thanks!
Old 02-21-2011, 05:45 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
I use a heavy duty clutch tool and a big hammer.
Old 02-21-2011, 05:46 PM
simplesimp's Avatar
simplesimp simplesimp is offline
2003 Chevy trailblazer ls
royal blue 4.2L I6 4X4
plenty of threads on this as i read a few over the weekend while changing clutch on my neighbors truck but what i did was loosen 2 screws and wedged a long screwdriver in them for leverage and with a crescent wrench and some muscle power turned the nut counterclockwise and viola! it broke loose. good luck friend. hope you get running soon.
If its dented sideswiped or just plain busted,I want it and cheap
Old 02-21-2011, 06:05 PM
Tarnished's Avatar
Tarnished Tarnished is offline
2005 Chevy TrailBlazer LS
Gray (Soon IRD Black) 4.2L I6 4X4
There is a huge thread on this, I think it was stickied also.
Try the chain and bolt method. It just requires 2 feet of chain bolted to the bracket above the alternator, and bolted to the pulley.
Old 02-21-2011, 07:51 PM
jjmoore59's Avatar
jjmoore59 jjmoore59 is offline
2005 GMC Envoy SLT
Carbon Metallic 4.2L I6 4X4
Some have good luck getting the bolt loose however I had to use the chain trick. It worked well, don’t get frustrated and plan on it taking more time then you think. I hear some say only took 30 minutes or so, it took me 3 hours soup to nuts but I am a little slow. BTW, there is a youtube on this.
Donít be Afraid be Aware
Old 02-21-2011, 08:10 PM
racer383s's Avatar
racer383s racer383s is offline
2006 Chevy TrailBlazer LS
Silver Blue Metallic 4.2L I6 2WD
Loosen this nut before removing belt.....that makes the pulley less likely to turn.....I've always had good success with a large crescent wrench & a hammer....
Eibach Lowering Springs-Flowmaster 70&SS Tip Spectre Air Filter-12" sub W/Amp-CAF MOD
Custom-Bilt Receiver Step-De-Racked
Old 02-21-2011, 08:17 PM
Ricky81's Avatar
Ricky81 Ricky81 is offline
TrailVoy Guru
2010 Nissan Altima 2.5S
Navy Blue Other 2WD
I rented tools from partsouce(autozone in the US)....complete wrench set in all different sizes meant for clutch fan removal and only took me about 15mins to remove the bolt....
Old 02-21-2011, 11:18 PM
Tried this but the belt won't hold the pulley tight enough and the pulley still spins.
Old 02-21-2011, 11:19 PM
Went there today and their removal kit consisted of a thin wrench of which my crescent wrench will do the very same job. If I can only hold the pulley tight enough......
Old 02-21-2011, 11:25 PM
This sounds the most promising. Did you tighten the new water pump to fan clutch in the same manner? If so, any problems? Thanks!
