Factory radio Unlock Code - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-23-2011, 02:30 PM
1BAD97X's Avatar
1BAD97X 1BAD97X is offline
2007 SAAB 9-7x
Carbon Metallic 5.3L V8 AWD
Hey everyone, I'm looking to install an aftermarket iPod adapter unit to my GM / OEM headunit (Uses band button and plugs into XM/Sirius harness) this weekend. Should I need to worry at all about an unlock code if anything is disconneted (I.E Power, factory harness, etc.)? Any help would be appreciated.
Thanks In Advance!
1BAD97X
2007 SAAB AWD 5.3l 97X
N00b Mods: Vanity Plate/K&N Cone Replacement/Weathertech Cargo & Floormats
Old 02-23-2011, 02:47 PM
GavinVoy's Avatar
GavinVoy GavinVoy is offline
2002 GMC Envoy SLT
Forest Green Metallic 4.2L I6 2WD
Thanks In Advance!
nope nothing like that is needed.
unless you got a new OEM unit, it would need to be programed by the dealer or an experienced mechanic, since each is coded specifically to each truck.
it's magically delicious
Old 02-23-2011, 02:53 PM
1BAD97X's Avatar
2007 SAAB 9-7x
So a loss of power or disconnection of wiring harness will not trigger a prompt for code? I'm doing the install on Sunday and do not want to have to make an emergency to to the dealer on Monday if this can be avoided.
Thanks!
1BAD97X
Old 02-23-2011, 06:44 PM
bromanjr's Avatar
bromanjr bromanjr is offline
Senior Member
2004 GMC Envoy SLT XUV
Indigo Blue Metallic 5.3L V8 2WD
You won't have an issue with the radio security.
The design of the Radio security is that when the radio is new (or has been cleared) it will pick up a portion of the VIN # from the vehicle BCM and store it for the future. This is similar to re-programming a used radio with a Tech II where a stored VIN portion is erased and then replaced with the current vehicle VIN portion. I have personally had a replacement radio for a different GM vehicle "cleared" by a Delco radio Depot (with proof of purchase) The radio then behaved like a new radio and copied the proper VIN portion when it was connected and turned on the first time.
When the vehicle is started, the radio and BCM compare the portion of the VIN that is significant, if it matches, the radio works. If you put a previously used radio (already has a VIN remembered) into a different vehicle, the VIN portion will not match and the radio shows "Theft Locked" (or something similar to this).
This type of security works very well and never locks your radio while installed in your vehicle, even after a dead battery, no codes to write down or translate.
Of course a malfunction in the components of the TheftLock system can cause a myriad of symptoms and the radio being locked may be one of them.
My
182,000 and counting. Superchips 2914 Tune, NAV upgrade.
