Rear Lift Gate Replacement Part - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Exterior
Exterior Exterior
Old 03-01-2011, 03:16 PM
dja3137's Avatar
dja3137 dja3137 is offline
2002 Chevy TrailBlazer LTZ
white 4.2L I6 4X4
I've posted in the past, what would be causing my rear tailgate to be rusting on the lower left hand corner. Its rusting from inside the panel out...so in order to fix the rust problem, i was told i need to replace the entire tail gate.
What are you guys' thoughts on this?
Second, I remember seeing the whole tailgate (replacement) up for sale, but i was unable to track this down...
Looking for a tailgate, no glass, no inners or trim, just the metal gate itself.
Other than a local junkyard, is anyone aware of a place to get one (OEM) at a decent price?
Old 07-09-2011, 10:43 AM
sanger35 sanger35 is offline
2002 Chevy TrailBlazer LS EXT
rusting through 4.2L I6 AWD
Rear lift gate rusted through.
My 02 rusted out too. I believe it was because the seal around the license plate module failed. Last time I checked it was about $1400 to get aftermarket tailgate installed and painted.
Old 07-09-2011, 11:48 AM
SparkyJJO SparkyJJO is offline
Seal around the license plate insert is a common failure. That then allows water inside the tailgate, which lets it rust.
I know, my tailgate has a brown spot in the center and another spot starting on the left corner, with paint bubbles along the lower edge from other spots starting to rust through
Tags
liftgate, oem, replacement, rust, tailgate
