P0016 Code - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > The Lounge > TrailBlazer / Envoy Chat
TrailBlazer / Envoy Chat The TrailBlazer and Envoy Owners and Enthusiast lounge. (no tech questions)
Old 03-03-2011, 11:48 AM
Mudduck07 Mudduck07 is offline
2004 Chevy TrailBlazer LT EXT
Black Granite Metallic 4.2L I6 4X4
P0016 Code
Hello Everyone - I am new to this site so learning how to navigate anyway I have replaced the cam Position sensor and the Cam Actuator - CLeared the code twice now and it keeps coming back - Some people are saying I need to replace the Cam Phaser Actuator Sprocket.
Is this the correct direction to be heading? My truck runs great but keeps popping the same code and I can't seem to get rid of it.
Jim
Old 03-11-2011, 11:18 AM
camshaft actuator gear assembly replacement
Ok so I have determined that the camshaft actautor gear assembly needs to be replaced.
My question is has anyone ever done it and can the above average home mechanic tackle this pretty easily? It seems that it isn't to difficult just need a few special tools The one step I am a bit worried about is the tension holding so you don't need to take everything apart. Is there a way of doing this with out the special tool and can anyone walk me through it or should I turn it over to the local mechanic - I believe it is going to cost in the neighbor hood of $700.00 and I think I can have all the parts in hand for around $200.00 if I do it myself.
Jim
Old 03-11-2011, 02:37 PM
Paisano Paisano is offline
2002 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
Welcome to the forums, first and foremost
I had to replace the camshaft actuator (the mechanical part) about a week ago; I was quoted $1,000 total, which I thought wasn't too bad (they also put in a battery I purchased outside of the dealer, so I saved money there). I was encountering a P1345 code, though.
As for a DIY'er kind of job, I haven't found any threads or posts here for replacing the camshaft actuator. I would have done it on my own, with the help of my buddies, but we didn't want to mess with the timing. I'd say its pretty iffy, but if you have the equipment, experience, and time, more power to you
Old 03-11-2011, 02:44 PM
bromanjr's Avatar
bromanjr bromanjr is offline
Senior Member
2004 GMC Envoy SLT XUV
Indigo Blue Metallic 5.3L V8 2WD
Camshaft actuator solenoid (have to move PS pump)
Camshaft phaser actuator gear assembly (have to remove valve cover and hold chain during replacement)
I'm not sure you guys are talking about the same part or different ones. These are 2 different parts, watch out what name you give the part.
182,000 and counting. Superchips 2914 Tune, NAV upgrade.
Old 03-11-2011, 02:56 PM
Black 4.2L I6 4X4
We are talking about the same part; the camshaft actuator is the mechanical part, while the camshaft actuator solenoid is the electrical part.
I am referring to the camshaft phaser actuater. The mechanical part yes
Old 03-11-2011, 03:08 PM
Black 4.2L I6 4X4
Glad to know we're on the same page
After the dealer had completed my fix-up, they mentioned that my camshaft phaser actuator was stuck at full advance, so I was averaging about 8 MPG... Sorry I couldn't provide much more information on the subject...I got fed up and decided to leave the annoying job to the dealer.
Old 03-11-2011, 04:02 PM
Mine is only sticking on startup( The initial 10 Second scan) which is throwing my code I can clear it but it comes back a day later - I may get lucky and with the warmer weather coming it may just go away until winter is back- Not stuck in advance or retard yet but I'm sure it's a matter of time.
Old 03-11-2011, 06:52 PM
Black 4.2L I6 4X4
Good luck with that, then! Hopefully it isn't anything too serious or expensive to fix
Old 05-29-2011, 06:14 PM
Suttmike1 Suttmike1 is offline
2007 Chevy TrailBlazer LT
Code went from P0014 to P0016
Was wondering if I could get a little help. I was getting the Famous Code P0014, so after looking on the site, I found that a Good oil Change and in my case, replacement of the Cam Timing selonoid, Everything seemed to perk up and now I had all of the lost power I was expirenceing. Approximately 200 miles later, I get another check engine light and when I checked it, I had a P0016 code. How should I proceed? Should I go ahead and replace the other timing sensor? I would worry about timing gears and chain except for the fact that it runs like a bat out of hell!! Any help is appreciated. I'll check back later to see what help I got.
Thanks,
Suttmike1
