Steering Wheel Shaking - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > OEM Issues
OEM Issues OEM Repairs & Problems
Old 05-11-2006, 05:02 PM
TMONEY-2125's Avatar
TMONEY-2125 TMONEY-2125 is offline
2005 Chevy TrailBlazer LT
Every since I put on my 20" wheels I have a vibration in my steering wheel when I hit 60+MPH the installers took them back off an double checked for balancing they came up good, they also put some plastic rings in the middle behind all 4 rims to fill the gap around the rim. The rims are 6/127 and suggestions??
Old 05-11-2006, 05:09 PM
deathbynosleep's Avatar
deathbynosleep deathbynosleep is offline
2004 Chevy TrailBlazer LT
Onyx Black 4.2L I6 4X4
could be time for some new rotors. Steering wheel vibrates when your rotors are warped.
Tim
Old 05-11-2006, 05:10 PM
dntnvme's Avatar
dntnvme dntnvme is offline
2005 GMC Envoy SLT
Liquid Silver Metallic 4.2L I6 2WD
Did you get your rims and tires new or used? Maybe you need a wheel alignment, but if you got them used they could be bent. I just put 22's and I have no problems at all. No shaking or anything
Stacy's 2008 Chrysler Aspen
Jay (dntnvme) 300C SRT 8
Hawthorne, Cali Swangin
Old 05-11-2006, 05:13 PM
dntnvme's Avatar
2005 GMC Envoy SLT
Forgot about the warped rotors. Check this first before you go on.
BPierce390's Avatar
BPierce390 BPierce390 is offline
2003 Chevy TrailBlazer LT EXT
Majestic Red Metallic 4.2L I6 2WD
lay off the brakes a little bit.. hope it gets fixed bro
Old 05-11-2006, 05:16 PM
I just put the rims one a month ago and only have 13,000 miles on the car could it be the rotors? Rims/Tires were brand new. Thanks for the posts everybody!!
Old 05-11-2006, 05:27 PM
Steve02SLT's Avatar
Steve02SLT Steve02SLT is offline
Senior Member
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
The rotors on the GMT 360's are notorious for the rotors warping. IMO they don't get enough air to breathe and cool down. They're also not large enough. Before getting rims, I would suggest looking in to upgrading to slotted/drilled rotors, or maybe a big brake kit.:m2
Old 05-11-2006, 05:31 PM
rsnow46's Avatar
rsnow46 rsnow46 is offline
2006 Chevy TrailBlazer LT EXT
You always go back to the last thing that was done before the shake started. With that new a vehicle it's not the brakes or rotors, it's in the balance of the tires or an out of round wheel. Something like this ususally shows up around 50-60mph. Was the balance a static or dynamic balance? Static=on a bubble machine. Dynamic=spun on the vehicle. Have them spun balanced and check for a out of round condition.
EnvoyXL's Avatar
EnvoyXL EnvoyXL is offline
2006 GMC Envoy SLT
Red Jewel Tintcoat 4.2L I6 2WD
Rotors will only make you car or truck shake when you are braking. You will also feels a puslation in the brake pedal. Unless you are driving around with your foot on the brake or only notice it when you are slowing down then skip the brakes.
Old 05-11-2006, 05:53 PM
ENVOY2LOW43's Avatar
ENVOY2LOW43 ENVOY2LOW43 is offline
2003 GMC Envoy SLE
I agree on the balancing. If rotors are warped you would only feel vibration upon braking. I would suggest go to a different tire service facility and have them check then have the other shop reimburse you with your expense if new balancing was done.
Dennis
Similar Threads
Problems with the steering wheel control BUC NASTY OEM Issues 11 04-13-2008 12:44 PM
Steering wheel vol and Sony remote pctravel Audio and Electronics 5 02-29-2008 05:23 PM
Serious Help! Cant pull out the steering wheel BUC NASTY Interior 12 01-21-2008 03:11 PM
Shaking in the steering Wheel TBSS07_Chappy Suspension 11 09-08-2007 06:52 AM
Steering Wheel Control Not Functioning Sims Envy Audio and Electronics 5 03-10-2007 11:10 PM
