2wd vs. 4wd - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-07-2011, 03:13 PM
splashback splashback is offline
2004 Chevy TrailBlazer LS EXT
Black 4.2L I6 4X4
2wd vs. 4wd
I just purchased a certified 07 Envoy SLT 2WD. It was a last minute purchase as my previous car was totaled. I live in the Chicago area- I am kinda kicking myself for not searching more for a 4wd.
I have never really needed a 4wd- not even in the most recent blizzard.
For those 2wd owners- how does it do in the snow? Towing? etc
Old 03-07-2011, 03:38 PM
ghoster ghoster is offline
2011 Chevy Tahoe
Mocha Steel Metallic 5.3L V8 4X4
I never had any issues driving my 2wd TB in snow. I stayed on main roads and used good sense about where to drive. That said, I was in Virginia. We had a few good storms, a couple of ice storms, but NOTHING like what I have driven through in Chicago. I did however drive my civic through some pretty good Chicago storms without any problems either. I think it comes down to how experienced you are are.
I remember the first snow my TB saw. The wife and I were leaving Norfolk heading for Miami for Christmas. We had about 8 inches of snow and ice crap on the ground. The TB wasn't having any problems.... save one. The window wash tank had frozen solid! You can imagine how cold it has to be to freeze that tank solid. For the first hour I had to stop every 10 minutes and wish the windshield by hand. It began to thaw after about 3 or 4 hours of driving, which was a couple hundred mile south, into warmer temps.
Old 03-07-2011, 03:49 PM
the roadie's Avatar
You'll have fewer problems if you got the G80 automatic locker option. Does your glove box sticker say "G80" on it?
Old 03-07-2011, 04:07 PM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
If I recall correctly, 07+ models come standard with Stabilitrak, which combines ABS, Traction Control and Stability Control in its functionality. That should get you through most on-road winter driving situations just fine, you just need to take time, go easy and let the electronics do their thing. When GM developed Stabilitrak, for demonstration purposes they took two nearly identical Yukons, one a 4x4 w/o Stabilitrack and another a rwd unit with Stabilitrak and guess which one maneuvered the snow & ice covered course better? ..... If you guessed the 4x4, you'd be wrong!
JFSebastian's Avatar
JFSebastian JFSebastian is offline
2004 Chevy TrailBlazer LT EXT
Can't imagine it
My EXT spins the rears way too easily. I wouldn't consider it if I had to drive in snow. Maybe with real snow tires instead of all terrain tires it would be ok.
Old 03-07-2011, 04:15 PM
jkust jkust is offline
Senior Member
2007 Buick Rainier
Imperial Blue Metallic 5.3L V8 AWD
Some of the stabilitrak comparison videos are amazing. Total catastrophe without and maintain control with. My bottom line is it's a truck, trucks should have more than 2wd. That's just the Minnesotan in me. I've never known anyone with only 2wd on a truck. We subject our trucks to all the stuff you'd want more than 2wd for.
5.3L, 3.73, Nav, XM, Entertaiment system, Heated leather, Moon roof, Chrome edge running boards, Chrome rims
Old 03-07-2011, 04:39 PM
I_hate_joining's Avatar
I_hate_joining I_hate_joining is offline
Silver Green/Silver 2Tone 4.2L I6 4X4
Go with snow tires in winter and you should not have to many problems. I had a 2WD Blazer with snows and had no problems in light snow.
The Stupid Shall be Punished!
Old 03-07-2011, 04:45 PM
Decembersend's Avatar
Decembersend Decembersend is offline
2003 Chevy TrailBlazer LT
Im orignally from Cleveland, OH. There were times I would use my 4wd but that was just me being stupid and trying to get stuck .
Most of the time I was in 2wd with decent tires and there were only a few spots I slipped but nothing big to cause an accident or cause the other drivers on the road to freak out
Marks 3" body/2.5" suspension lifts, HD Bilsteins, 1.5" Spacers, G80
David - Southeast Chapter Member
Old 03-07-2011, 04:54 PM
bromanjr's Avatar
bromanjr bromanjr is offline
Senior Member
2004 GMC Envoy SLT XUV
Indigo Blue Metallic 5.3L V8 2WD
Have '04 2WD with the G80 option and almost new tires, no problem this winter going anywhere I needed.
182,000 and counting. Superchips 2914 Tune, NAV upgrade.
Old 03-07-2011, 07:08 PM
Fishsticks Fishsticks is offline
2002 Locked Up Chevy TrailBlazer LTZ - Black w/
Herculiner and Rock Rash 4.2L I6 4X4
If by chance you don't have a G80 you're not completely out of luck. Since you have an EXT you have the same rear axle as a full sized truck, the 8.6" 10 bolt.
This means you could use this:
http://www.justdifferentials.com/ind...oducts_id=3716
The installs on those are easily done in your driveway with simple hand tools. You'll have a fully locked rear axle that releases when you need to turn. That will help get you moving in the snow, and the Stabilitrak will help you continue to move in the direction you originally intended.
